VIORE LCD TV/DVD won't turn on
Red power light flashing.
  • 3 more comments
  • fredrivera19 Aug 18, 2008
    Woke
  • rsearle Dec 24, 2008
    our 19" did the same thing, first it had no picture but sound. Now no sound either. Has anyone found a fix for this?
  • huawang2002 Jan 01, 2009
    I bought a 37 in HDTV ready monitor from Viore about 3 years ago. Not long after I bought it the sound did not work. Now I can not see any pictures. The red indicator could turn blue. But no pictures.
  • mcmahon15 Jan 23, 2009
    Small GE TV/VCR combo. Power light clicks on and off, but won't turn TV on. My problem is that there is a tape in the VCR and I can not get it out. Any suggestions?
  • therubles4 May 01, 2009
    Have the exact same problem. No picture, fuses are good. What to do now???
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Posted on Dec 24, 2008
Our 42 inch Viore is almost 2 years old, and it suddenly stopped producing a picture. You cannot even see the volume bar. It has perfect sound, but absolutely no picture. Any ideas of how to fix it or how much it will cost. It is a plasma tv.
Thanks
Sandy
Posted on Oct 29, 2008
I have a Viore 42 inch TV and this morning i had it on and i heard a loud bang like a gun shot and I have no picture but have sound what do i do please help
Posted on Mar 25, 2009
TV will not stay on. The red and and green light stays on at the same time. Viore 50 inch
Posted on Nov 06, 2008
My onix 40" Fhd LCD tv has power going in (red
In order to ensure, it is not caused by the input device, connect a DVD player and see. Also look for any loose contacts in power outlet, RC jack, cable and socket. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | Televison & Video
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
Dish remote code for Viore 32" HD LCD
Hi, my name is Cheri Torres and I am with DISH Network customer service. I came across your post and wanted to see if I could help. DISHNetwork remotes have a few different codes for each of our different models of remotes.You should be able to find your remote model number on the back at the top ofyour remote it's usually a two to three digit number with a decimal point. Iwill list here for you the best codes for the most common DISH remotes and alsothe instructions for addressing your remote to your TV. The only codes that I was able to find for the Viore TV were for the 5.3 IR remote and the codes are 563 and 500. If these codes do not work you can also try running a channel scan to find your particular code. I will also list here for you the instructions for running a power scan. I hope you find these codes and instructions useful and if you have any further questions or concerns feel free to post back here or email me at Cheri.Torres@Dishnetwork.com. :)
Instructions for addressing remote to TV,
  1. Turn the Television On
  2. Press and Hold the TV mode button down until all the mode buttons (i.e AUX, SAT, TV etc.) light up.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Instructions for running a power scan
  1. With the desired equipment on, press and hold the TV button down until all the mode lights light up.
  2. Press 500 using the number key pad.
  3. Press the pound(#) button once.
  4. The TV button will blink red three times.
  5. Then again press and hold down the TV button down until all the mode lights light up.
  6. Press and release the big red Power button once.
  7. Press the Up button once every second while pointing the remote at the desired equipment. Keep pressing the up button until the TV turns off until.
  8. AS SOON AS THE TV TURNS OFF Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  9. Try the functionality of the TV to see if the power scan worked.
Nov 29, 2010 | DISH Network IR Remote Control
Dish network code for a viore, volume/power not working
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 05, 2010 | Toymax Viore 42 in. Plasma TV
Tv wom't switch on
Replace capacitors on power board.
Aug 29, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
VIORE tv/dvd combo
If the red light flashes at plug in you likely have a main board that is bad. If you have to press the power button before the red light flashes you likely have a bad bad supply board. This will need to be diagnosed by a technician to be sure of the problem.
Aug 18, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
3,146 people viewed this question
Top Televison & Video Experts
Electro Med Services...
