Question about Ariston Technologies L63 Free-Standing Dishwasher
ARISTON ARISTELLA LS 603 A Faulty door
The door on the dishwasher falls straight down does not release slowly. Think iy could be a faulty hinge spring. Does anyone know how to dismantle to have a look
3 Suggested Answers
SOURCE: need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Posted on Oct 14, 2010
GodBlessU
  • 3513 Answers
SOURCE: I cant open the door
Thank you for contacting fixya.com.
Pull the dishwasher out, unplug it. Look on the back of the top panel and there are screws. Undo this then slide the top towards the front of the dishwasher and it will lift off. In the middle front top there is a small plastic arm with one nut, undo this then the door will open. Then ascertain if you need a new latch mechanism.
Please get back to us if you have further query else please accept the suggestion.
Posted on Jun 21, 2011
Ariston l63 is not rinsing proper cycle but instead flashing 12hr light
Error messages,
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "G" flashing rapidly.
24463930-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Flashing LED diode above the mark 12h (drying) indicates faulty NTC thermistor. So, could be faulty: thermistor NTC, wiring between NTC and control board, control board.
Dado
May 20, 2014 | Ariston Technologies L63 Free-Standing...
LCD is flashing on and off every 2-3 seconds and makes the draw opening sound as it does this. There are no fault codes, rather all signs illuminate on/off with LCD. Try to turn of with power on/off but...
The controller is faulty. You will have to replace it.
Make sure the power is turned off when you work on the dishwasher as it brings mains power inside the door area.
Dec 31, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
The door to the dishwasher is very hard to close. The door also falls down to the floor which makes the carriage/basket fall down as well.
sounds like one or both of your door links are broken check your hinges. you should ahave a large spring and a piece of rope that attaches to the door. let me know if this helps you
Jan 05, 2010 | Frigidaire PLD2855RFC Dishwasher
Door drops down hinges faulty ???
no,if hinges were faulty door would fall off.there should be a spring mechanism in your door which allows it to lower slowly.
Nov 26, 2009 | Televison & Video
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston diswasher trips out as soon as door closed
hi On many dishwashers, the latch engages a switch to activate the timer and other control components. If the latch is not completely engaged or if the switch is faulty, the machine will not operate. Here's how to test and repair a door switch:
Step 1: Latch the door and hold the latch tightly in the closed position. This works best on a unit with a lever-type latch. Then turn the control to the ON position. If the unit works, the problem is probably a misaligned lock unit. Adjust the lock unit with a screwdriver. If this doesn't solve the problem, the switch may be faulty.
Step 2: Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Remove the panel covering the door switch and remove one of the electrical lead wires of the switch from its terminals. Clip one probe of the VOM to each switch terminal and shut the dishwasher's door. If the meter reads zero, the switch is working. If the meter reads higher than zero, the switch is faulty and should be replaced.
Step 3: Replace the switch with a new one of the same type. Connect the new switch the same way the old one was connected.
Oct 13, 2008 | Ariston Technologies L63SNA Stainless...
LOOSE DOOR HANDLE
Remove 4 screws(Torx 20) along both sides of inner door liner. Be sure to have a good grip on the outer door as it will fall off. I always start at the top of the door and work down. You may have 2 blocks fall off, they go on the hinge and fit on only 1 way with the slot on the hinge.
May 10, 2008 | Bosch 24 in. SHX36L05UC Stainless Steel...
My dishwasher trips out on certain cycles
sounds like faulty wiring inside unit. your circuit breaker is detecting an overload current condition...must look inside for wire touching frame. if none found, then wire fault may be inside of a device like motor or solenoid, so check these with ohmeter to ground-each wire (except chassis gnd) must be isolated from ground.
Jun 05, 2007 | Ariston Technologies L63SNA Stainless...
Ariston Technologies L63 Free-Standing Dishwasher Logo
1,174 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
