1. IDE is Integrated Development Environment
2.With VB 6, one can develop applications with feature rich GUIs (Graphical User Interface). Many varieties of general purpose software can be created with little effort, including, but not limited to,
image editing software,
text editor and
database applications.
3.Windows Application Template
Used to create Windows-based applications that run locally on users' machines. You can build anything from a simple single-window tool like Windows Calculator to a complete application with multiple windows and advanced capabilities.
Class Library Template
Used to create reusable classes or components that can be shared with other projects.
Console Application Template
Used to create command-line applications, programs that run from a Windows command prompt and have no visual interface.
My Movie Collection Starter Kit Template
Used to create the pre-built My Movie Collection sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
Screen Saver Starter Kit Template
Used to create the pre-built Screen Saver sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
4.FormShaper lets you change the shape that windows draws your forms. You can have rectangles, rounded rectangles, ellipses, polygons and any combination of the above! Even save the shapes to a file for use in other projects! See readme.txt in the zip file for more details
5.Description
Used at script level to force explicit declaration of all variables in that script.
Syntax
Option Explicit
Remarks
If used, the Option Explicit statement must appear in a script before any procedures.
When you use the Option Explicit statement, you must explicitly declare all variables using the Dim, Private, Public, or ReDim statements. If you attempt to use an undeclared variable name, an error occurs.
Use Option Explicit to avoid incorrectly typing the name of an existing variable or to avoid confusion in code where the scope of the variable is not clear.
