Sounds like a short key is being activated when you are pressing series of buttons disable short keys on your PC options menu or hold down the shift key then disable the short/hot keys menu
Odds are it just died but you can try programming it just to make sure.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in your 4 digit code and press enter. If this doesn't work it is dead. You can get a replacement keypad at Sears. Be sure to take the model number of the old keypad with you. It should be on the back of the old one. If not, take the model number of your opener. There are several models of keypads and all of them wont work with your opener.
I fitted a new keypad on my 960i some time ago (funnily enough for the same reason - no.7 not working!) and I'm pretty sure you will find that when your new membrane arrives, it is a complete unit with buttons and contacts all enclosed together, connected to the phones' circuit by a ribbon with a tiny plug on the end.. hope this helps....
front key pad needs replacment. it fits like a sticker on the front panel. Before you can remove it, remove the outer cover and disconnect the ribbon cable.Once done, peel off old keypad from front and reverse proceedure with new one.Reconnect ribbon cable.
FUNCTION SET 01 DATA REGISTRATION 02 DELAYED TRANSMISSION 03 POLLING 04 MEMORY REFERENCE 09 REPORT 11 UP 13 + 14 LEFT 15 SPACE 16 RIGHT 18 CLEAR 19 DOWN
Keys
1-20 are speed dial keys. If speed dial is not set, message is
displayed and manually entering the telephone number is prompted. Press
STOP to clear.
Pressing FUNCTION accesses the menus associated
with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET,
and occasionally the telephone key pad are used for selecting options
and setting values.
EG. Setting a speed dial number: FUNCTION
- DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET -
UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to
enter value - SET
EG. Setting unit telephone number FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
EG. Retransmit from memory (assumes memory light is on) FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
EG. Delayed transmission place
document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter
time to send - SET - PHONE KEYPAD to enter phone number - SET - SET -
document is scanned and will be transmitted at set time
for full guide you will have to search and purchase one.
You can try programming but if it still doesn't work then your keypad is just bad. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in your 4 digit code and press enter.
You're kind of vague on your problem. If it's the smaller blue numbers for the calculator, you will need to use the function (fn) key. Hold the fn key and press the key the reads number lock (num lock), this should return the keys back to letters. You can find more info on the fn key and numbers lock under help in the start menu. If this isn't your problem, be more specific, and I'll be more than happy to help.
If you are referring to the Number keypad. Tap the "Num lock" key and you will see a light flashing. Make sure the light is on when you stop. Now try the keypad.
