Question about EliteGroup K7VZA Motherboard
Power problem i think
Hi i have an EliteGroup K7VZA Motherboard when i plug the power supply into to the board the light on the board comes on but when i turn the power switch on the fans starts going but i do not hear beeps and there is nothing on the monitor even when i pull the keyboard and memory out i get the same thing, nothing just the fans going
please any help thanks ed
  • 655 Answers
If there is no beep, even after removing RAM means you have faulty Motherboard and/or faulty Processor.
Try to reconnect CUP also clean the CPU socket on board and try to test without RAM, if you got long beep (RAM missing) then proceed further i.e. add RAM, HDD, CD/DVD etc step by step.
If didn't get any beep try to test with other motherboard/CPU to find which one is faluty.
Please post your feedback.
Thanks and Good Luck
Iqbal
Posted on Aug 18, 2008
661fx-m7 no display ,, no boot ,, led indicator lights on
did you instal the driver for it? if not download from here http://www.nodevice.com/driver/company/Elitegroup/Motherboard/page11.html instal it and check if is working.                              if you have instal the driver then if everything on the board is working fine if some piece is malfunction then it must be changed.
Dec 14, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
I have a K7VZA motherboard when i turn power on
The very first thing you need to do is unplug all drives inc power.
Now remove as many add in cards as you can without compromising the system.
Try to boot at that point.
If it boots re-connect each piece of hardware one at a time until you find one that causes a problem.
Double check that item for any issues and replaces if needed.
If you have had the fan off the cpu for any reason then you should have cleaned both the cooler fan underside and the top of the CPU and put fresh thermal grease made for that purpose on there. DO NOT use too much as that is almost as bad as too little.
Is the fan the correct type eg motherboard takes 3 pin and fan is 4 pin ?
Make sure it is connected to the CPU FAN pins on the board and not system fan.
If you have another computer and the fan can be removed from the cooler itself you could plug it into the system fan port of another computer to try it out.
under no circumstances should you run a system without the CPU cooler running as it could cause irreparable damage to the CPU
Aug 18, 2009 | EliteGroup K7VZA Motherboard
No Power to Motherboard...
Here are some steps.
Attach the monitor in your CPU and plug it, see if the monitor powers up. If it did, then no problem in your power supply,
Detach the RAM or Memory of your CPU and put it back in, in the different slot. and power up your computer.
Check the cpu power switch if it is correctly attached to the motherboard.
Oct 26, 2008 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Disabling COMM ports
If you're pretty sure its your comm ports, boot up into your bios setup screen. (Tap Del while booting) Then go to the onboard devices page or any page that lists your com ports and change the property value to disabled.
Regards,
Worldvet
Jun 19, 2008 | EliteGroup K7VZA Motherboard
Emachine t3958
First check to see if a drive died. Unplug all the drive Floppy, hard and dvd or burns. I have come across many time that a drive will die and keep motherboard from booting. Being that you say you get a green light on the motherboard shows that the power suppy is providing some power. But for some reason the internal self test is faulting the power suppy. I have not come cross any bad power supplies killing a motherboard. But I have come across power supplies killing drives. The power switch is a normal open switch so the only time you be able test continuity on it is if you hold the switch in, or the closed position.
Apr 03, 2008 | E-Machines eMachines Desktop PC
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
Is motherboard dead?
Either motherboard, ram module or if no power at all sounds more like a power supply. If the computer has on board video you will need the ram to get any video. But with it removed the board should still beep if the case speaker is connected to the board. Have seen a lot of these less expensive motherboards fail. If there is no power up at all or lights coming on on the case I would think it is a power supply problem. Happens all the time and quite easy to repair. Just put on a new power supply.
Dec 12, 2007 | EliteGroup ECS P4M800-M Socket...
Motherboard
Well you really need to get a manual for that. Check the website and download the manual with that model, for sure there is one.
I guess you have connected all the connectors there incorrectly so better look for a manual.
Dec 09, 2007 | EliteGroup ECS 755-A2 Motherboard
No power to motherboard
Hi, Make sure you plug in a 4 pin power connector to the motherboard for the processor or nothing will fire up. It's usually yellow and black.
Jun 12, 2007 | EliteGroup P4M800PRO-M Motherboard
EliteGroup K7VZA Motherboard Logo
102 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
