Question about Compaq Armada E500 Notebook
Keyboard problem with keys
Especially the @ and £ keys do not display there does not appear to be a keyboard lock key that I can see at all? can you assist please
Sound problam
Posted on Aug 18, 2008
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Where is the Scroll lock on the keyboard of lenovo laptop?
    To Turn on/off Scroll Lock do one of the following: Press the Scroll Lock (sometimes appears as ScrLk) key on your keyboard. If your keyboard does not have a Scroll Lock key, on your computer, go to Start, All Programs, Accessories, Ease of Access, and then click On-Screen Keyboard.
    Jul 14, 2014 | Compaq Keyboard
    Unlock number lock
    On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
    Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
    Feb 28, 2013 | Acer Aspire Computers & Internet
    My led indicators for caps lock num lock etc not workinh in my lenovo G570 laptop
    Hi, If you are using a keyboard that is wireless im sure you just have to change the battery on the keyboard.
    However if the keyboard is connected to your CPU, then depending on your keyboard model, you may have to turn F LOCK (F Lock Light on) to access system key commands if they are labeled on the front of the keys, such as num lock , scroll lock and print screen.When you click on the Flock, the lights are either supoosed to click on or off.
    view the keyboard status lights by using the On Screen Display (OSD) option, Ensure you download the software ,
    from your start menu do a search for your keyboard, on th key tabs setting,
    its important to make sure that the correct model number is entered,
    double click on the light you wish to change, in the Reassign a Key wizard,
    clear the Displays (key name) status on the screen check box to disable the on-screen display, or select it so that a check mark is in the box to enable it, and then click Finish.
    Jan 26, 2013 | Computers & Internet
    What's the best way to unlock a Caps Lock key that won't unlock by simply pusing the Caps Lock key to unlock it?
    goto start > run > type "osk" and click ok...
    On-screen keyboard will be displayed...
    select keyboard in the menu bar... select 102 keys...
    Use the Lock key in the on-screen keyboard... it will turn OFF/ON the CAPS lock
    Jan 15, 2011 | Microsoft Computers & Internet
    When I hit the 'l' key, the number 3 appears.
    press shift + num lock and see if works. you should have a green led under the display. when press SHIFT + NUM LOCK , the green led state should change
    Jul 19, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
    Cannot unlock Keyboard Scroll lock - EX110
    Found this little bomb shell after about 30mins of looking for an answer.
    To toggle your scroll lock key:
    1. Click on the Windows Start button.
    2. Select Run.
    3. Type 'OSK' in the dialog box.
    4. Click on OK.
    5. The Microsoft on-screen keyboard will open. Notice that the slk, or scroll lock, key (located in the top row of the on-screen keyboard as shown below) is turned on.
    6. Click on slk (in the top row of the on-screen keyboard). This will toggle the state of the scroll lock key. Notice that the scroll lock key is no longer outlined in red. Scroll lock is now off.
    NOTE: If you have installed SetPoint (Logitech’s Mouse and Keyboard software) the confirmation message Scroll Lock Off will also be displayed for about 2 seconds on your monitor.
    Aug 21, 2008 | Logitech Cordless Desktop EX110
    Laptop keyboard on lifebook c, replace or fix
    It looks like you answered your own question - you really can't fix a laptop keyboard, but you can replace them. (or you can use an external keyboard)
    Now is your problem:?
    Letters qwert, asdfg, zxcvbn work OK but uiop displays as 456/ jkl displays as 123 and m displays as 0. Other keys also do not display correctly. Or holding the function key down at the same time as the problem keys ?
    Then the solution is:
    The problem was caused by accidentally pressing the num lock key. Once pressed, it remains locked even after a reboot. Pressing again returns the keyboard to normal.
    Jul 22, 2008 | Computers & Internet
    @nd function on keus
    It appears that the function key is stuck on. try an external keyboard. if the external keyboard has the same problem its an issue with windows but if not you could be looking at a replacement keyboard. hope this helps Peter
    Mar 28, 2007 | Sony VAIO VGN-FS640W Notebook
    Compaq Armada E500 Notebook Logo
    44 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Lee Durbin
    Lee Durbin
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
