Question about Whirlpool Duet GHW9150P Front Load Washer
Door locked/ cycle won't complete
I have a front load washer. I am getting a F11 error. The cycle stops in rinse/ spin. I canceled, unplugged nothing the door is locked and I can't get another cycle to start. My clothes are trapped inside
  • malachi236 Aug 18, 2008
    thank you so much. My laundry is free. I still have to have a repair guy in to find the f11 error. that one I won't try. But my laundry is free!
  • 5,911 Answers
If you need to get the washer door open, there is a manual release lever that you can use. The following links explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Now, with your clothes rescued, the next link explains the "F11" error:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
I know it seems like a lot with the second link. In most cases I have found, the CCU is the cause of the F11 error code, but read through the information carefully and doublecheck everything. It can be replaced if you wish to perform the repair yourself. I hope this helps you.
Posted on Aug 18, 2008
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
HE4t 45981 Washer dl f and F11
The DL F error is saying that the door lock mechanism is faulty and will need to be replaced.
Mar 05, 2012 | Washing Machines
It's STUCK
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer. Please post back for any further assistance.
Daniel
Jul 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine wont start. The door lock
You will have to replace the door lock wax motor.
May 21, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Model GHW910PWO shuts down during the rinse,spin cycle
First, pressing cancel twice should clear the error code and it should restart when you press start. Then you can press cancel to stop the whole thing This should also unlock it. Unplugging it for a long while may also clear the code and unlock the door, not sure.
the F-9 says it is an overflow condition and may need to be serviced. The F-11 says there is a serial communication error.This might be the case if the pump is running overtime due to clogging.
 See  http://appliancejunk.com/forums/index.php?topic=1785.0
To check if the filter is clogged, open the front panel, put a bucket in front of the unit, unseat the rubber feet holding in the white plug,  pull the white plug out so when you unscrew it, any water will run into the bucket, then unscrew it and clean the filter. screw the filter back in, set the white plug back into the unit, being sure to secure it with the rubber feet.
As for it stopping, you may be filling it too heavy and the motor stopped if it over heated?
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F11 and f dl errors
I hope that you have a serivce contract or something on this unit you need a main control board f11 means that there is communication error between the 2 computer boards the fdl means that there is is door lock problem. But that is incorrect that is how you know which board has the problem the door lock is controlled by the main computer board. it's just playing tricks on you I have tried changing the door lock with those codes and it did nothing. that board tends to be alittle pricey .good luck.
Dec 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
NOTE: If the error remains on the display, call for service.
What causes the HE3t washer to stop in spin and rinse cycle?
Sometimes the unplugging helps, or hitting "Cancel" several times.  Guaranteed to work though is to remove top, reach down the top to the door lock.  (Tight squeeze and need to be a little tall to reach) Once your hand is down there, on bottom of lock mechanism is a small handle that must be pulled straight down and manually unlock the door.  This can also be accomplished by removing lower front panel and reaching up to do the same.   BTW, while in the top, make sure all the electrical connections are tight.  I found some loose before, probably from the spinning action.
Dec 06, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
212 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
