Question about Samsung ML 2010 Laser Printer
Toner error i got a paper jam in my samsung ml-2010 printer and when i took the paper out it told me that the toner cartridge was not inserted correctly. i took out the toner and put it back in, but still didnt work. i even put a new toner cartridge in and it still has a red light when i turn it off and then back on again. help!!!!
  • pharmdude Aug 18, 2008
    it was just like any other paper jam i've had. i took it out in two pieces, but it wasnt that hard to get out. i was reading somewhere else on here about taking out the fuse and putting it back in?
No unfortunately.
can you tell me how to fix the fuse? i want to try anything! is the fuse part of the toner cartridge or part of the printer itself? because i have already tried replacing the whole toner cartridge with a brand new one and that didn't work.
Posted on Aug 19, 2008
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm..not good. when you took out the paper jam, did it come out easy?
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
  • Patrique Davenporte Aug 19, 2008
    well..that's a possible. is this unit still under warranty, by chance?
How do I insert a new toner cartridge to my Samsung SCX 4600 ? Ken Mallinson.
Hi
The toner cartridge door is located above the paper tray, Just pull it off and remove the toner cartridge.
Jan 13, 2011 | Samsung ML 2010 Laser Printer
The online light stays red and I can not print anything. what should I do?
check the toner cartridge. red light means there is an error in the printer. check for any paper jams. check paper tray settings.
Oct 01, 2010 | Samsung ML 2010 Laser Printer
Online error light nothing prints
I have a ML 1710 .Not my area of expertise but I took out the paper and could not see a jam. Took toner out , a little cleaning, plugged and unplugged from computer several times. I found paper jammed in the very back ,folded so tight nothing was showing. Mine has a back door and the paper is having trouble rounding the last bend and coming out. So I leave the back door open to get my copies. Green light on.
Feb 26, 2010 | Samsung ML 2010 Laser Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
Laser printer ml 2010, paper pull in problems
I also have the ML-2010R and I also had the paper feed problem. with warnings about paper jam around toner cartridge.
After a bit of reading and people mentioning the big roller that picks up the sheet of paper and that it needs replacement; I decided to carefully try to clean that rubber roller.
I used a brush and medical alcohol to clean the roller. After letting the roller dry I put in some paper and tried to print again and for me it works like a charm!
Jan 19, 2009 | Samsung ML 2010 Laser Printer
On line/error and toner/save lights on
try to find some jam paper inside your printer or try to re-insert the toner cartridge....
Oct 26, 2008 | Samsung ML 2010 Laser Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Printer ML2010 not responding
On Line/Error LED
lights red
receiving data.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Samsung 2010 printer
Mine did the same thing, turned out to be an empty toner cartridge. The one that comes with the printer when you buy it only prints about 50 sheets before it dies.
Mar 13, 2008 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser printer
LSU means "Laser Scanner Unit". That is the part that actually "prints" the image on the drum before it goes to the paper. If the toner (not ink) cartridge is in good condition, then you need an Authorized Service Center to replace the LSU assembly.
Oct 22, 2007 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
135 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
