Question about Samsung 24 in. DB5710DT Stainless Steel Built-in Dishwasher
Indesit dishwasher DI 450 wont work
The dishwasher has powere going to it but program 2 and 4 keep flashing and now it wont do anything
I had this problem and you have probably resolved it by now but I thought i would respond so that anyone else searching would get some help!!!
If program 2 and 4 are flashing it means that the filter is clogged and needs to be cleaned. Switch the dishwasher off - take out the filter and clean it and ensure all debris removed from in the filter housing. Pop it back in and switch back on and now the machine should work.
Mine is now running good as new!!
Posted on Oct 08, 2008
SOURCE:
Indesit DI 450 fault codes
Doyou have your Owner's Manual? If you do, look on page 11, your filter needs to be cleaned out.
First, unplug your machine, then take out your tray. Find the screws and remove coverings. That should take care of your problem, if you get it thoroghly cleaned! Let us know what happens!!
Jul 29, 2014 | Indesit Dishwashers
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Hi, our Indesit IDL500 dishwasher has stopped working. The fault light 2 is flashing. The manual doesn't mention what fault this indicates. Any ideas. Cheers, Neil
Hi Niel, If you were to start the cycle from the beginning, where in the cycle does this occur? . So many code numbers for so many units, hard to keep up .Just note if heating is taking place and if drainage is correct. Hear from you soon.
Sep 26, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit DI 620 dishwasher lights 2 and 4 flashing
Lights 2 and 4 flashing - can't start machine. This fault not covered in manual.
Apr 21, 2009 | Maytag MDB5100A Dishwasher
Indesit DI 620 which won't drain water
this appliance is a built in dishwasher and may have somthing jamming the pump,this can only be acessed from the bottom and may require the appliance being removed,also check that there is not a blockage at he sink.
Apr 19, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit idl530 2 flashing lights
no, turn the on / off button off, then turn off the power for about 5 minutes and then it should work again. and at some point do contact someone to look at it.
Jun 13, 2008 | Indesit 24 in. D63 Free-standing...
Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Apr 12, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Di67 s dishwasher
Try tilting your dishwasher forwards. Be warned that water will escape from the front. I have had this problem and paid an engineer to come and tell me this. If your machine is not completely level water collects at the front and does not empty. This then causes the machine not to work. Good Luck
Dec 18, 2007 | Indesit 24 in. DI67 Free-standing...
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
Samsung 24 in. DB5710DT Stainless Steel Built-in Dishwasher Logo
431 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
