Question about Intel Motherboard
Hi - Benimur
Thank you for your response
I have one more doubt. how we can reset CMOS/BIOS to default condition?
    Brigadier General:
  • 6,966 Answers
Hi again,
If your motherboard is for a desktop, there would often be a 3 terminal jumper very near the Lithium battery marked CMOS Reset. A jumper is currently positioned shorting one end and the center, temporarily removing this jumper and moving it to the opposite end/pair would reset the CMOS/BIOS. Alternately, you can also remove the 3.0Volts coin size battery for about 30 minutes wold reset the CMOS/BIOS.
Cheers.
Posted on Aug 18, 2008
Bios password removal
Have you tried resetting bios to default? There should be a jumper on the motherboard that says CMOS default or BIOS default. It is usually 3 pins with a jumper across 2 of them. Changing the jumper to the other unused pin and center pin, labled default, should reset bios to default and remove the password.
Jan 16, 2014 | HP Touchpad Tx2-1377nr...
Tip
How to reset the bios password using PC CMOS Cleaner.
Burn the PC CMOS Cleaner iso ..using ImageBurner or Nero
1.Start up
Insert PC CMOS Cleaner CD, Set BIOS to boot from CD/DVD-ROM.
The first page presents to user is : PC CMOS Cleaner is ready to run.
PC CMOS Cleaner will try to decrypt the encrypted password store in CMOS and list the possible results in the list box:
BIOS type : the type of the BIOS.
Possible passwords:
possible passwords store in current computer. The passwords are listed between '' .
3. Reset the BIOS to default state
If the possible passwords do not work. PC CMOS Cleaner will try to reset the BIOS to the default state.
This action will blank the BIOS password. You may also lose all your previous settings.
There are two choice for you:
Choice 1: Reset password (try to keep date and time)
This choice will try to reset the BIOS, but keep the date and time.
Choice 2: Reset bios (all setting will be set to default, password will be erased)
This choice will reset all data in BIOS to default state.
Please try the Choice1 before Choice2.
on Jan 12, 2011 | Microsoft Windows XP Professional
ZX4800-06 (PWG8502023)
Hi Louie,
If you teared down your all in one and the motherboard is in front of you , look for the CMOS battery and just reseat it. it will reset the BIOS on your motherboard.
Or if you want you can go to the BIOS page and look for the option that says "reset to defaults" . Go to bios by tapping F2 key while restarting your computer.
Hope this helps.
Thanks.
DENNIS
Jun 23, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Mobo fried? Beeps when startup but no video. I reseated ram and video card, with no luck. Both fans work and it sounds like it is booting. I tried older video card too but nothing. Thanks for any...
Try removing the display card and using the onboard VGA. Remove the BIOS/CMOS battery for about a minute and then reinstall it in the correct orientation. This will reset the BIOS/CMOS to it's default settings. You say it beeps once, this means that it is fine the mainboard is ok, it is not experiencing any problems. If it beeps in a continuous manner then it is the RAM that is causing the problems, I would say that the default settings may solve your troubles. Remember to enter the BIOS/CMOS when during boot up to reset the date and time by hitting the delete key. Also try entering the BIOS/CMOS even if you can't see any thing on screen, by doing this it may come up. let me know how it goes, I am here to help.
Thanking you
damnor01
Nov 09, 2010 | HP Compaq Presario SR5450F Desktop PC
Bios pass word
You can clear bios with factory defaults reset.
For that open back cover of your laptop.
Then pull cmos cell from motherbord for 10 minutes so all bios settings are defaults.
Then put again cmos cell in it's position then it not ask password.
Let me know if you need more assistanse.
Thanks.
Sep 18, 2009 | IBM ThinkPad R40 2681
Sir my toshiba laptop is under bioword and i donnot know password .sir, listen how to open motherbroad satille a205-s5861 thank u sir
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
Jul 29, 2009 | Computers & Internet
Start up no response on screen
OPEN THE CASE A REMOVE THE CMOS BATTERY FOR 3-5 MINUTES THAT SHOULD RESET THE CMOS TO DEFAULT SETTINGS. OR GO INTO THE BIOS AND SET TO DEFAULT SET UP.OR DEFAULT SETTING AND REBOOT.YOU MAY ALSO HAVE A CMOS RESET JUMPER.CHECK MANUAL FOR MOTHERBOARD.AND FOLLOW THOSE DIRECTIONS.RICHARDM69
Nov 30, 2008 | Acer Aspire M1640 Refurbished Intel...
Hi Benimur
Appreciate the direct "Ask Me".
To your concern, initially pls try:
  • remove the memory sticks;
  • clean both slots with a clean dry toothbrush/paintbrush. You could also use a can of compressed air or an electronic contact cleaner spray;
  • clean the little gold pins of the memory using a pencil eraser.
  • If the above is not sufficient to address the issue, pls try resetting your CMOS/BIOS to default condition.
This is of course assuming that there is no hardware fault.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Intel Motherboard
Worked great until last night....
hi put some exhaust fans in the case see if this will help youi had this happen to me a few times add fans and als wellremember you still have your chip set on your mother board they do not have fans and need to be cooled too
Nov 03, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Intel Motherboard Logo
469 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
