I switched on the progressive scan on my LG home theater LH-T550SB setup by mistake.
It so happens that my TV is not capable of Screening a Progressive Scan signal .
Please help me to restore it back to the normal mode
Just click below;
hope this may help;
Regards,
VOTIT
Look for a reset for the LG in the user manul,sorry cant help any more.
CABLE GUY.
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
OK.
Thanks for your for trying.
All the same i got a solution as below:
1.Switch on/standby mode.
2.Remove disk from from the system and close it back.
3.Press the Stop button for 5 sec's.
4.The nomal OSD function will resume.
Best of Luck everybody
