Question about Maytag MZD2766GES Side by Side Refrigerator
Admiral refrig The freezer is 17 degrees but refrig is 56 and the fan comes on and off as it always has this refrig is 2 years old. The fan the other day was making alot of noise. Now I can not get the refrig temp to come up even on the highest setting.
    Champion:
  • 210 Answers
Thats the fan hitting ice. sounds like a defrost problem. does the back of the freezer panel have any frosty ice build up?
Posted on Sep 14, 2008
We have a Whirlpool with the freezer on top. The freezer is around 5 degrees, but the refrig. won't go below 47 even at the coldest setting. We vacuumed all of the vents and tubes in the lower front
The fan in the freezer may have stopped working. Or it could be the defrost drain tube is stopped up. Remove the rear plate in the freezer to expose the fan motor. With the rear cover off You can see if the freezer box has frozen over the drain. If so unplug refrigerator use a hair dryer to melt the ice. Keep heating the drain area until water runs down through the drain. Fan motors are available by model number on line or at local appliance stores.
Dec 30, 2013 | Whirlpool Refrigerators
Frigidare refrig. It seems like Freezer still working but not refrig. Temp is now 56 in refrig part. Refrig is not even 2 years old. Fan seemed to be working in refrig earlier but now not at all.
check the damper vent door between the two compartments to make sure its open to let the cold air in from the freezer then make sure the evaporator fan is operating to help push air thru this door,sometimes these doors freeze shut or if its a motor driven vent door the motor could be bad too
Jan 01, 2011 | Refrigerators
When compressor tries to turn ''on'' a loud ''click'' can be heard. The fan in the ''freezer'' compartment blows semi-cool air (stays at 56 degrees F). It will cycle like this. Have since unplugged it...
Good day,
Either the start relay mounted on the side of the compressor has failed, or the compressor has locked up or lost it's start winding.
You can pull the relay off the compressor after removing it's cover and have it tested. If it tests bad, replace it. If it tests good, then the compressor needs replaced.
Mar 11, 2010 | Maytag Admiral Top-Freezer Refrigerator
Refrigerator won't cool less than 52 degrees
I can tell you if it can be fixed by you or if you need service. Just answer a few questions as we go through this. Pull away from wall and remove the lower panel. Feel top of compressor and see if too hot to keep your hand there or cool. Let me know if freezer fan and fan below are running. Answer those and that will help me answer your questions, Thanks Sea Breeze
Feb 15, 2010 | Maytag Admiral Top-Freezer Refrigerator
Freezer and fridge not cool enough
Check if the syrofoam pieces block air inlet. If so then this may be the problem.
May 08, 2017 | Admiral Refrigerators
Cold but not frozen
23 years old ? That thing was costing you more than a new unit would cost for the past 5 years!
Assuming your airflows are good, Its time for a new refrigerator.
Aug 29, 2009 | Refrigerators
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Moved refrig this morning and now it is not cooling... freezer works great
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
May 12, 2009 | Refrigerators
Kitchenaid built-in refrig 15 yrs old cold freezer, warm fridge
it.s the frezer that makes the refer cold.the evap fan in the frezer moves that chilled air to the refer.if that fan is slow or any blockage inthe air ways it slows that process.Also the frezer should be close to 0 degrees if theres a defrost prob that would make fresh food warmer
Dec 31, 2008 | Refrigerators
Maytag MZD2766GES Side by Side Refrigerator Logo
109 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
