Question about Acer AL1916W 19" LCD Monitor
INPUT NOT SUPPORTED
I POWER ON CONPUTER THE WORD ACER COMES UP ON SCREEN THEN SCREEN TURNS BLACK AND THE WORDS (INPUT NOT SUPPORTED) STARTS TO ROTATE ROUND THE SCREEN CAN YOU PLEASE HELP? KIND REGARDS PETER DAVID MAYS.
  • sinhamcp Aug 21, 2008
    same problem when i boot my system its booted but there is a massage popup comes like" Attention input not supported"
    how to rectify it , any solutions.
    plz help.
  • Shri Deva May 11, 2010
    can u please be more specifical about the problem i mean like about the operating system and the ur output device.. [VGA CARD] ??
The Acer 1912 Horizontal Sync seems to be a common problem.
On the Intel 910GL it was running 1280x1024 at 60Hz just fine and then one day it started having problems so I switched to
1280x1024 at 75Hz and is ok again. I have a couple other video cards an ATI and a NVIDEA I'm going to test it on and I'll post the results after I do. Oh yeah and of course its XP Pro running on a ASUS P5GL-MX.
Posted on Sep 03, 2008
Is this on a Linux pc? I had this problem with a Viewsonic and Ubuntu. I had to play with the Horizontal Sync and Vertical Refresh till I got it right.
Posted on Aug 22, 2008
Input not Support
It sounds like the resolution for your computer graphics are not compatible with your display.
In any case first thing to check is if the monitor cable has been disturbed; next try powering-down (everything) and leave it for a few minutes, power back-up and see if it fixes itself, if not Power-down, wait a few seconds, Power-up then press Shift & F8 as soon as Windows starts loading (you have to be quick, so might need several attempts), that should get you to the recovery Screen, then Try TroubleShoot and Automatic Repair.
Also, you might strt up in Safe mode. If your montor works, might be the driver.
Jul 26, 2015 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
Acer aspire 5515(laptop) screen is black turns on screen stayscompletly black...no acer logo nothing just a black screen. power button comes up green u can hear the fan and harddrive start up
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 02, 2013 | Acer Aspire 5100-5033 Notebook
When i put pc on this message comes up on screen saying input not supported and it floats round in a little box.
This generally means you have the display resolution set higher then the monitor can support. To fix this press F8 after you turn the computer on. You may have to press it a couple times before the windows loading screen. A black menu will come up. Select safe mode. Your PC will load into safe mode with minimal drivers and settings. Go to the control panel and select display. Change your screen resolution to something lower then the setting is is at right now. If your screen is 19" or smaller try a setting of 1024x768 for starters. If its 20" or higher try 1280x1024 for starters.
Regards, Chris
Jun 30, 2011 | Acer Computers & Internet
BLACK MONITOR...INPUT NOT SUPPORTED
This is the resolution problem. Pls reduce the resolution . Right click any where on the desktop and click on properties there. a popup appears just choose Setting there . there you will find the option of Screen Resolution .Just Slide the pointer toward less litlle till your problem resolve.
Sep 04, 2009 | Acer AL1916W 19" LCD Monitor
We have a flashing rounded rectangular box moving around on the screen which says input not supported. What does this mean? How do we fix it? this is happening on our Acer Monitor for our computer.
Right after you start up the computer, start pressing f8. You will then get into a setup, choose VGA mode. If this does not work, try lowering the refresh rate and changing the screen resolution.
Aug 03, 2009 | Acer AL1916W 19" LCD Monitor
Acer 5315 dont open. black screen appears
Sounds like a registry problem. Are you running XP or Vista? When you go to task manager, click on File /Run. Type the word "explorer" without the quotes...Does the start bar come up?
Mar 06, 2009 | Acer Aspire 5315 Notebook
Input not Supported
Run in safe mode and try to change the screen resolution to 800x600 and reset your machine.
Oct 27, 2008 | Acer V193w LCD Monitor
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
Aug 28, 2008 | AOC A15X221 15 in. LCD Television
Input Not Supported
You need to go into display settings, click advanced, and then click the monitor tab, and change the hertz setting to 60 HZ
Aug 07, 2008 | Acer AL1916W 19" LCD Monitor
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
216 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
