Whirlpool 6th Sense AWM 8121 front loader washing machine....was working fine...but now it stops at the wash cycle and stops..so I loaded the wash with less and less weight to see if that was the problem...I runs fine with no clothes in it but it can't run even a few of the kids school shirts ....the spin speed drops to 1200 to 0 and thats it.....Ive checked the front filter and its seems clear..... any suggestions??????
  • Anonymous Mar 10, 2009
    i have the same problem. it happens on any cycle. are wash motor capacitor's or wash motor brushes expensive to replace?
  • 49 Answers
It will either be the wash motor capacitor or the wash motor brushes. both of witch will have to be tested by an electrician
Posted on Aug 18, 2008
My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
Hello Janine Gooch,
Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
Finally ended up in AU ... No luck.
(September 9th is only 6 hours old here (SF Bay area)).
Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
Whirlpool WFS1071BD Question and Answers
Hope this helps (says top load... shows front)
Carnac the Magnificent
Sep 09, 2017 | Whirlpool Washing Machines
Wanting a user manual for whirlpool 6th sense wfs1071aw front loader washing machine please
go google and type in--operators manual fro whirlpool washing machine model wfs1071aw --- and down load the pdf version
Jun 12, 2017 | Whirlpool Washing Machines
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Front loader whirlpool washing machine won't go thru cycles.
"o" is an unsual code. usually it will have an "f" then a number. it may be that you are having a draining issue. is the unit full or have some water left in it? if so take off the front panel and see if you can remove the sump cover. be ready for water to come out, then remove whatever is blocking the pump and sump area. it most liekly has lint or items in there causing no drain.
Dec 28, 2008 | Washing Machines
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
HI, I am having a lot of trouble with my front loader which is only about 4 years old. It seems to become very unbalanced during the coloured wash setting (even with a small load) - and yet is perfectly...
check teco coil on the back of the motor, it may have come loose'its about inch round thing it gives power to the the speed control module circuit board thats why its tumbleing too fast.bye Eamonn Ireland
Jun 11, 2008 | Whirlpool Washing Machines
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
674 people viewed this question
Top Washing Machines Experts
