Try this
- Remove the cartridge that is not working.
- look for a lint free cloth "coffee filter" then dump w/ water
- clean the copper contacts of the cartridge
- make sure that the air vent is open; if not pinch it a bit
- remove all the cartridges
- check if there are are inks spills
- use lint free cloth to clean the part where you are have trouble with
- install the inks again
- run alignment and clean cartridges on the panel
if still nothing works, call HP tech support and ask for replacement of the ink.
note: they will do the same steps again for troubleshooting and documentations.
the reason why this happens:
- that the copper contact does not touch each other
- cartridge air vent is sealed
- not an orig HP ink
- Print head problem, needs cleaning
If you need more help come back.Post /
thumbs / testimonial are
welcome!
