Question about Electrolux Kitchen Ranges
How do I change oven element in Electrolux EUC5110W?
  • 49 Answers
Witch element
Posted on Aug 18, 2008
  • anonymous111 Aug 18, 2008
    does it have a fan forced element at rear and an element at the bottom
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Nov 14, 2017 | Electrolux Ovens
The top oven is over-heating with no change in temp display. A red-hot heating element on the left side of the oven (facing it) shows through the floor of the oven.
Good Morning Eileen, thank you for your inquiry!
I understand that your Electrolux double wall oven is having over heating issues. It is possible that this could be a faulty thermostat, control panel, or element. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. If you need help locating a technician you can visit your manufacturer's website for additional assistance with locating a technician. I hope this information is helpful to you. -Matt
Aug 09, 2015 | Electrolux 27" Built-In Double Electric...
How to replace the lower, hidden bake element in the lower oven of an Electrolux Icon oven
You need a 1/4 or 1/16 mm. to take it out, they always have a simgle plug.
Nov 13, 2013 | Electrolux Ovens
Frigidaire electrolux oven gallry series front right element won't turn off
What is the model number? Reset the unit by unplugging or turning the circuit breaker off and then retrying.
Aug 09, 2012 | Frigidaire Ovens
My Electrolux EOB5610 fan oven will not heat up. The power light is on. The oven light is on. The fan works. There is some heat in the oven but not enough to cook with.
Only two possible causes. The oven element is faulty or the oven thermostat controller is faulty. Probably the first thing to do is test the oven element and check the resistance. If the element is okay then the oven thermostat will need replacing.
Feb 23, 2011 | Electrolux EOB5610 Ultrafan Electric...
My electrolux EOD5330 fan oven tripped a fuse. ow it won't heat. The fan still works
Most likely problem is the the oven element short circuited which caused the fuse to blow. When power is restored everything generally works except for the element. If you check the element you may find a blow hole in it.
Feb 10, 2011 | Electrolux EOD5330 Ultrafan Electric...
I have an electrolux EOU 6330 double oven, how do I gain access to change a faulty element?
Assuming you live in the u/k, and it is an electric fan assisted oven, and that it is the fan oven you are referring to, then the element is usually to be found at the rear of the oven compartment, behind a removeable cover.
Hope this helps.
Dec 10, 2009 | Electrolux EOU6330 Electric Double Oven
Bottom element broken
Mark,
There should be an element on the top, used for broiling, and then one on the bottom. If you look inside the oven carefully at this element and the top as well, should should be able to see a small blown out spot, or even a break.
If you do, turn off the range at the breaker box, and two screws should take it out. Take that and the model number of your stove to an appliance parts dealer. It won't be very expensive, although he may have to order it in for you.
If the above is not the case please write back.
Sirwriter
May 16, 2009 | Electrolux Ovens
Replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Nov 17, 2008 | Electrolux EOB5610 Ultrafan Electric...
Kitchen Ranges Logo
117 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
