Question about Lexmark S305 IMPACT LEXS All-In-One InkJet Printer
ALL IN ONE S305 USB does not seem to work , i cannot press continue to install onto network , its a new usb B male to male ?
  • Official Brand Answer
  • 3,344 Answers
The Lexmark S305 printer uses a USB type A on one end and type B on the other. Type A end goes into your computer and type B end goes into the printer. Make sure the USB cable is properly inserted.
Posted on Jun 19, 2011
SOURCE:
Why lexmark s305 on USB sometimes fails with communication error?
You may want to check the sites below for help with regards to your issue.
support lexmark com
May 16, 2014 | Office Equipment & Supplies
Just reinstalled windows 8. Now printer (Lexmark s305) will not print. It is connected through the internet; but says "no communication" when hit "print". What am I missing?
firstly printing through a network need to ensure you have internet access weather home or form the office.second having correct printer driver is very important. uninstall old drivers check devices manager for installation and devices details. if the problem persist check your USB printer cable the following link should be of help. http://www.lexmark.com/publications/pdfs/2007/2009-fall/v9842009_en.pdf
May 06, 2014 | Lexmark S305 IMPACT LEXS All-In-One...
USB Not Working
It would seem that you are trying to make a backup rather than installing the software you believe you are installing. I would format the USB drive and start again.
Jul 12, 2013 | SanDisk SDCZ52-032G-A11 32GB Cruzer Switch...
Plug & Play recognises Dub E-100 attached and device manager lists it however continually get error 39 driver missing or corrupt. Drivers loaded directly from CD supplied / also download version...
Hi.Try to install again your windows xp.need fresh windows xp installation because same of your operating system software device corrupted and missing.to recognizes that USB network adapter gadget.
Jun 09, 2011 | D-Link DUB-E100 (DBDUBE100) USB Network...
Netgear N150 Wireless usb adapter just installed. It identifies router and confirms good connectivity, but continues "acquiring network address" without success.
This means the DHCP service is not enabled on the wireless router.
either enable the DHCP service on the wireless router
or
Give a static IP onto your wireless NIC card ( Netgear N150 Wireless usb adapter )
Dec 06, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I got a new laptop and i lost the installation CD for my wireless g usb adapter I have the linksys compact wireless G USB adapter
You can the software direct from Linksys here.
Just download and copy the file to a usb flash drive, or burn it onto a cd and you're good to go ;)
Sep 25, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
I recently purchased a new pc hp2009m and the cord on my lexmark e250dn does not fit my pc how can i adapt please advise. Colin
This printer has three standard ports: bi-directional parallel, USB, and ethernet (RJ-45). Most likely your previous computer had a parallel port. The simplest solution is to get a USB cable (Male type A to Male type B - 6' or less in length is recommended.) Install the software on the computer then connect the cable to the port on the back of the printer and to the computer (the square end goes to the printer and the rectangle fits the computer). The USB port is in the same area on the left side of the back of the printer as the parallel port.
Alternatively you could get a network switch and connect the printer as a networked printer. The ethernet port is near the middle of the back of the printer.
http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_E250D&segment=DOWNLOAD&userlocale=EN_US#1 has the software and drivers for support OS versions.
I hope this helps.
(Getting a bidirectional parallel to USB adapter is cludgy when you have a USB port available.)
Jul 01, 2010 | Lexmark E250dn Laser Printer
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
I would like to download pics from a digital camera to my computer but the computer is old. I see no port for digital card
Do you have the CD that came with your digital camera?
IF so, put it in your optical drive, and install the software.
This CD contains the drivers for your camera.
Drivers allow your computer to 'communicate' with you camera.
Now obtain the correct USB connector that plugs into your camera. Should be a male Micro, style of USB male plug,
http://en.wikipedia.org/wiki/File:USB_types_2.jpg
The plug all the way to the left in the photo.
They sell USB cables that have this style of male USB plug on one end, and the usual USB A style on the other end of the cable.
Male. The male USB A style, is shown all the way to the right in the photo.
Looking at the usual style of USB plug, compare it's size to the Micro USB plug.
Yes, the female version of that plug is on your phone.
There is also a kit made by Philips, that has 5 different adapter ends of the USB style, in the kit.
The adapter ends just plug onto a male USB A style end.
The kit comes with a Male A USB to Male A USB cable.
It's rolled up on a tiny reel that is about 1 inch wide, and is retractable.
You just grab the ends of the cable, and pull out the length of cable you need.
This gives you an idea of what I'm referring to,
http://www.walmart.com/ip/Emerge-Tech-Retractable-USB-2.0-A-Male-to-A-Female-Cable/12575359
With the software from your camera installed on your computer, and the USB cable plugged from your camera to your computer, you are able to download.
Some camera's have it so you turn the camera on, and open the shutter. Your camera may differ. Check your camera user guide.
Another way is to buy an All-In-One card reader.
Plug a USB cable into it, and your computer.
This is an example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1187796&CatId=962
(Scroll down the page to watch the animated gif demonstrating the card reader. Right above the large, red Ultra 3 Year Warranty heading)
Jan 31, 2010 | Compaq Evo D510 Minitower (Open Box)...
Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
118 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
