Question about Brother Office Equipment & Supplies
New printer installed today,printer will not print throwing paper out the back of printer,cannot change programme to copy ?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Ok...remove the drivers..go to www.brother.com for fresh set, install..run a test page 1st..then try it again.
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
My Canon Pixma MP 280 printer will not feed the paper through when printing. A spring has come out from somewhere, where might it go?
Buy a new one bro. Thrift shop has those things for $30. Buying a new one is only like $60-90. No one on earth knows where that spring goes and it's not worth your time if you can throw it back in the box and take it back to the store.
Also, Ebaaaayyyyyy~~~~
Canon PIXMA MG2520 Inkjet Photo All in One Printer Print Copy Scan 8330B002
Nov 10, 2014 | Office Equipment & Supplies
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
Installed new printhead,took new ink I had just put in old printhead and put it back in new printhead. Will print nothing.just spits put blank 4x6 photo paper it says to load in to get calibration.Then it...
The document specs of your printer is given below:
Document & Media Handling Max Original Size Legal (8.5 in x 14 in) Original Type Sheets Min Copy Size 3.5 in x 5 in Max Copy Size Legal (8.5 in x 14 in) Standard Media Capacity 100 sheets Output Trays Capacity 50 sheets Document & Media Handling Details Input tray - 100 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ Output tray - 50 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ ADF - 3.94 in x 5.9 in I would rather suggest to take a print in normal A4 size plain paper and see what you get. Please revert back Suspected 1) paper scanner faulty not able to judge paper.
Sep 10, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
POOR RINT QUALITY ON 4 PART INVOICE/DELIVERY PAPER
SRibbon wont effect multi part forms, well it will only effect the top one. Most dot matrix printers also have a impression adjustment, sounds like you need to increase yours.. it brings the print head closer to the platen.
It could also be the paper, not having much carbon to print the next part.
I've also notice you ask a lot and suggest you may need more than simple one line free answers.
Font problem will be program or print driver or even possible printer default settings (read printers user manual) .ie.font used by software is probally not supported on 2nd line so a default font is used
Once you have read manula you will find and know how to change print quality ie draft or LQ.
After reading manual you should also discover you can do print quality adjustments via the oprint driver.
Jan 26, 2009 | Epson LX-300 Matrix Printer
New cartridges - printer not printing
Align your cartridges to solve print quality problems such as: • Characters are not properly formed or are not aligned at the left margin. • Vertical, straight lines are wavy. 1 Load paper in the paper support. 2 On the control panel, press Copy. 3 Press Options until Maintenance appears. 4 Press the right arrow until Align Cartridges appears, and then press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
Please rate this solution.thanks and good luck.
Jan 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
I have a Konica 2223 copier - wont print on edges
check all edge settings .f28 is code for charger corona just clean corona assembly with cerosene oil and change corona wire with new one.
Dec 16, 2008 | Office Equipment & Supplies
Photosmart C4280 all-in-one. Problem is only with label paper. It prints 3/8" too high throwing everything out. If I change the original, it is fine for three or four sheets but then changes again. It...
You've probably tried this, but I did have success today with Avery 8160 labels. I had been using 5260 labels. There is a difference at the top of the page in the way the backing lines up with the labels.
Nancy
Nov 30, 2008 | Office Equipment & Supplies
We had problems to print legal and after 30 minutes of trying it finally printed legal. Now we cant go back to letter size so every document prints on legal paper. Can I get clear instruction on how we can...
When you say printing? Do you mean from the computer or are you making copies. If you are printing from the computer you need to change the paper size that you are printing to under the printers properties or the out put tray. If you are making copies just hit the reset button or just manually select another paper tray on the display pannel. Or if you have change a paper tray to leagal size change it back to LTR and make sure the paper is installed the correct direction.
Nov 26, 2008 | Canon imageRUNNER 2200
18 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
