SOURCE: Phone is Locked on headset setting even though there is no headset connected
best thing to connect a headset and take it out, that will trigger the function that it will come back to handset.
Good Luck
SOURCE: not showing songs in playlist in n73 me
refresh ur play list there is a option of refresh in music player.
SOURCE: headset connection
That is just is a simple problem. Sometimes our phone chooses the accesories that we attached, sometimes it appears unsupported,my brother also has the same proble w/ you but he have solve it by changing the headset and it works, just try it.
SOURCE: Nokia 6234 headset not connected but phone thinks
have you try to turn off your unit and try to open it again?
If still there you will need to normal reset your phone, try to save all your files, back it up , remove the memory card and the sim card and open your unit again
press *#7370# then if it required code then type this code 1234 or 12345 (unless you change the security code)
then try to open it again
SOURCE: my nokia n73 handphone cannot start
PLEASE unplug the battery from the system(phone) for at least 2 minutes reconnect the battery and power the phone back on
