Question about Lexmark Office Equipment & Supplies
HI MY LEAXMARK X4550 WILL NOT FEEL THE PAPER IN PROPERLY CAN YoU HELP? Julie
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Sure..look underneath the printer, and see if there's anything stuck in the paper tray feeder.
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
Printer ejects paper without printing
Hi Julie,
- When you try to print is the the front door isn't securely closed? the front door you open to insert the dvd things might not be closed well, please check it.
Hope this helps, please feel free to contact if the problem is not solved or you can come to a chat room for troubleshooting here. thanks!
Oct 24, 2011 | Epson Stylus 1400 InkJet Photo Printer
Why does my paper jam half way as it tends to
I had this problem till I started using heavier weight paper. My wife was buying the cheap really thin paper and it was no end of trouble.
May 27, 2010 | Lexmark X4550 InkJet Printer
Paper jam/ printing problem
I have this printer and when this did it to me like its doing to you the FEEDER had to be replaced. Now you might want to see if all the rollers are rolling and nothing is in the paper path. Also check you paper weight and size and adjust accordenly. A new feeder is like $27 bucks and you would have to go 3rd party to get it. I got mine from a USED lexmark someone was saling off ebay for my fix.
Please be considerate and leave a ratings and postive feedback for your free answer today.
May 26, 2010 | Lexmark X4550 InkJet Printer
Paper does not feed into printer
Printer Lexmark X4550 not taking paper, (Quick Fix)
Hi, yes my printer had the same problem with the pick up rollers not taking paper,
and thought it would be a simple job to adjust the springs inside the printer? But no, I could not find to open the printer. So I devised a simple modification using a
thin flat spring I had taken from an old windscreen wiper blade. see instructions
Good luck, bigvern
Jan 10, 2010 | Lexmark X4550 Multifunction Wireless Color...
PAPER KEEPS GETTING JAMMED.
This could be due to several things. Here a very complete set of instructions on how to resolve and prevent paper jams in the X4550.
http://bit.ly/aO5xwd
Dec 18, 2009 | Lexmark X4550 Multifunction Wireless Color...
Hi, i have a lexmark x4550. The pick up roller (the roller that grabs the paper and feeds it into the printer to get printed on), is not working, at least one of them isnt (there are two i think,,, but on...
Try the following: take an A4 sheet of paper and glue a 2 - inch strip of sanding paper onto the top of the sheet (full width of the page). sanding paper should be about 120 grain.
Now feed the page with the sand paper first (rough surface on top) into the paper inlet. grab and hold the paper, then press paper feed or send a print job. The printer tries to feed you special sheet, but you won't let go. This will sand off the gunk from you feed rollers and give a bit of rough surface to the rubber. Repeat if needed, it should cure the problem.
This works if the problem is the roller surface, it will not fix a problem with misalignment or a missing/broken spring in the feed roller mechanism.
regards, the perfessa
Aug 23, 2009 | Lexmark X4550 Multifunction Wireless Color...
Paper Jam/Cartridge can't move
Hello Julie how are you? Regarding on your problem try to remove your cartridge then installed it properly. Or try to open the back of you printer and try to see if their is a small piece of paper left during a paper jam incedent you have.
Jun 16, 2009 | HP Officejet 5610v All-In-One InkJet...
Lexmark X4550 - paper jam
My Lexmark did the same thing-if you can get in at the rollers to clean them that might help.
Jun 09, 2009 | Lexmark X4550 InkJet Printer
Paper being fed crooked on my lexmark x4550 printer
Make sure your printer trays are lined up properly for the paper size you are loading.
May 10, 2009 | Office Equipment & Supplies
My lexmark x4550 keeps rejecting paper and says vlear paper jam
I'm not sure what step have you taken to remove the paper. However in general you may need to shut down the printer properly. Please refer to below article that might be helpful for paper jam issue on LExmark printer.
http://etech.maiila.com/?p=25
Apr 29, 2008 | Office Equipment & Supplies
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
