I"m trying to hook up this Emachine and im having proble4ms connecting cdrom floppy hardrive
Hi sorry bout the confushion ineed help connecting floppy hdr cdrom on emachine tower
  • 1 more comment
  • jazzyk2184 Aug 18, 2008
    If someone could she post a picture of the inside of a tower model #50002 64900730 i would greatly appreciate it thank u
    how would i know the difference
  • Anil Manjunath May 11, 2010
    need to know if this would be a external (USB) or internal you are trying to connect.
    regards
    Guru:
  • 859 Answers
An external drive would have a cable you connect to the back of your tower. An internal would not have this but would connect directly to your motherboard on the inside of your PC Tower.
Based on your follow up question it appears you want to connect to an inside pin out connection point. Is this right? And if so, what type of cable do you have that need to connect? Is it thin and round or flat and wide?
Thank you for your patience. One of use will be able to help you further once you post this information. Sorry, but we actually need to konw this in order to solve your problem.
Regards,
Worldvet
Please use th comment box below to reply.
Posted on Aug 18, 2008
Hi I just bout a LG plasma modle 50pt250,ta and im trying to hook up my surround sound to it, but I dont know where to put the RCA cables on the back of the tv?
You can't do that, this tv doesn't have RCA audio outputs. You will have to connect it using the Optical output - an optical cable is required.
Mar 19, 2011 | LG Televison & Video
Emachine come up where it ask for me to hit f10 or f2 but it wont do anything. My keyboard or the mouse wont work. My emachine is a w3050. Looking for a diagram of how to hook hardrive cd and just to see...
Are you using a wireless mouse or keyboard? If so try using one that you plug in. As for the cd rom and hard drive all you need is one cable for each device hooked to seperate connectors on the motherboard. Ususally the hard drive will be sata which is a red cable and can only go onto one connector on the motherboard. the cdrom is an ide cable(grey usually) and there is a seperate connector for that on the mainboard.
Jun 10, 2010 | E-Machines eMachines Desktop PC
Booting method of libretto50ct
Best thing to do is,try to get a Windows 98 cd from a friend who has some computer skills and ask them to temporarily put in a cdrom drive in order to begin the process of repair.You will also need them to hook up a floppy drive in your computer,as you will need the floppy disk,containing the files to load the cdrom drivers and setup files to do the repairs to your windows 98 operating system....if not,you may need to upgrade to windows xp or Vista.Good luck:)
Apr 12, 2010 | Toshiba Libretto 50CT Notebook
Start up error message issue: floppy disk fail
if im correct, you havent installed a floppy drive yet...
while the comp is booting press esc (on some comps its F10 it should say on the screen) and access the boot sequence..in there there is a list of boot items...they always list floppy drive as the first boot drive in case you need to recover your comp...remove floppy drive from your boot list making sure that your hardrive (C) is first drive to boot.
After you get your comp set up, you may want to change that sequence in case you ever have problems with your HDD
add a comment if you need more help
Jun 22, 2009 | EliteGroup K7S5A Pro Motherboard
Monitor doesnt reckinize that the hardrives on
try taking the ram chip out then see if thats the prob by turning on the computer without it if its not, try unhooking the cd drive and then try turning on the computer if thats not it then try unhooking the hard drive and check if thats it one of those should be the problem i had the same prob but i messed with the ram chips and it worked i just took it out started it up and it worked if thats the prob just start it up then shut it down and put the ram chip back in and it should be fine
Jun 10, 2009 | Northgate (STAX2517C2) PC Desktop
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Mike
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
Ilunable to read from hard drive or cdrom from p4i65g
Try changing the IDE cable which connects your CDROM to motherboard. Also make sure that Master/slave configuration are properly set if both the hard disk and the cdrom are connected with a single cable
Nov 25, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Motherboard problems
Sorry for the delay in help. If you haven't gotten your pc running yet i suggest you check the cpu. It sounds like it is over heating.
Sep 04, 2008 | Computers & Internet
HI no startup beep on my emachine and no signal onscreen
Get a new Hard Drive and plug it into your USB Port
Jul 05, 2008 | E-Machines eMachines Desktop PC
Boot problem - Win98SE
change the boot sequence in bios set up ...
keep in this order
first boot device as floppy
2.hard disk
3.cdrom
then save it and then have a check it should work ..
you have not mention hard disk here so i think the hard disk is not detected there may be some loose contact inside and it is not connected properly so it is not able to verify DMI pool ...
if so connect the hard disk properly then then have a check it will surely work..........
Feb 23, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
320 people viewed this question
David Payne
David Payne
