Question about Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum
There is a high pitches nosie coming from my dyson. It mainly happens when the flooring type changes whilst hoovering. Everything else is ok. It sounds to me like the drive belt for the brush bar or could it be the clutch. Hoover is over 10yrs old but is in good order and well looked after, this is really the first thing that has ever gone wrong with it.
  • Dyson Master
  • 1,420 Answers
The clutch has belts in it which lose elasticity and should be replaced frequently for proper performance. The brush bar also gets hair and debris that works its way into the bearings and main shaft. Check this area thoroughly and clean or replace as necessary.
Posted on Oct 02, 2017
  • 357 Answers
SOURCE: Dyson Animal DC07 making a horrible noise!
The sound is just there to tell you that the brushes are not spinning. Awful huh? lol Well, the problem with Dyson is that they are very difficult for the customers to fix themselves. You can try to reposition the brushroll ends, but without a belt lifter, it's pretty hard to do. I suggest calling Dyson directly @ 312 469-5923.
Posted on Oct 16, 2007
  • 126 Answers
SOURCE: Hoover Windtunnel not picking up as well
There is a height adjustment on these vacuums and they are set to adjust in the "handle up" position". It will appear that the adjustment is doing nothing when the handle is up, but the setting will take affect when the handle is lowered.
You can check the brush length with a pen or pencil. Turn the machine over so that the brush is visible and run the pen or pencil flat across the bottom plate. Any where the brush is extending outward, your pencil should contact the bristle. If not, then the agitator should be replaced.
Also, check to make sure that the agitator is rotating freely and that the filters and bag are allowing for adequate suction. The machine will only pick up if the air flow is sufficient.
Posted on Mar 23, 2008
  • 328 Answers
SOURCE: dc11 dyson
I dont think its a problem with the filters if you have normal suction.
If the DC11 cylinder/ canister vac has an air turbine brush / turbo brush check that the drive belt inside it isn't clogged with dirt. If its a toothed belt ensure that it is properly snapped on as well as the other parts in that floor head tool. There may also be dirt clogged in the turbine wheel which is stopping the brush from moving quickly.
Posted on Mar 30, 2008
Agent Don
  • 310 Answers
SOURCE: brushes not going round
The brushes on my dyson have stopped going round. I have checked it and they move freely by hand. The belt is intact. What could the problem be? The Hoover is about 10 to 12 years old.
My dyson is a dc04
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
One of the main problems with vacuums are that the flat belts on the vacuums stretch and should be changed every 4 to 6 months or 3 or 4 times a year – you can tell by taking off the belt or belts on the vacuums and compare them to the old belts on the vacuum the new belts will fix inside of the old belts and you will be able to see the difference on how much they have stretched – if the belt is a geared belt – they stretch as well but should be changed about one a year – the cost is not that expensive and you cleaning will improve almost double – this also applies for the Dyson DC04 and the Hoover vacuum as well – some of the Hoover vacuums have two (2) belts and they both should be changed @ the same time.
Posted on Apr 15, 2008
  • 37 Answers
SOURCE: hoover turbine replacement
first you must remove the dirty water tank then the nozzle window on top of the machine. (this is the clear piece that the dirty water is sucked through.) then remove all 8 screws from the bottom along with the 1 screw on the main housing. after all this the top housing will be snapped into the base at two spots in the rear of the upper housing. when these are loose the housing should be out. you will find the turbine in the front along with 2 more screws and 2 hoses that also must come off. attach new part and reassemble.
good luck!!!
Posted on Sep 24, 2008
How do I assemble this hoover
Hi Peter, it's Jack at Dyson.
DC40 Multi Floor should be quick and easy to assemble - no tools are needed, the parts will just clip together. Our Getting Started video guide shows you everything you need to know:
I hope this helps. If you need any further advice, just give our experts a call. You can reach the Dyson Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Mar 01, 2016 | Dyson DC40 Multi Floor Upright Vacuum
My dyson makes funny nosie when iput it on
It really depends on what sort of noise it is making but if the motor seems to have a higher pitch to it than normal, I would suggest that it is a blockage of some kind.
Please have a look at the following troubleshooting guides to try to resolve this as well as the video.
Removing blockages from the wand and hose
Removing blockages from the main body
If you continue to have difficulty, please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
Oct 27, 2015 | Dyson Bagless Upright Vacuum DC41 Animal
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson dc33 makes a high pitch sound occasionally when using on carpet. Doesn't happen on hardwood floors and it's only 2 months old.
I'm sorry to hear you're having difficulty with your DC33. If you're concerned about an unusual noise the machine is making, I'd encourage you to get in touch with our Helpline. We'll be able to run through some troubleshooting over the phone with you to help resolve this.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Dyson Online Customer Support
Mar 15, 2012 | Dyson DC33 Bagged Upright Vacuum
High pitched sound
make sure the filters are pushed it all the way and the pipe work is clear
Jul 26, 2010 | Dyson DC25 All Floors Bagless Upright...
I cleaned out my dyson ball as it smelt when i hoovered, cleaned filters, washed out canister and took the screws out of the front bar so i could clean near the brushes.. now its making a high pitched...
Hi its Darran at Dyson.
The screws on the base of the cleaner head should not have to be removed to access the brush bar so it is possible that the brush bar has come out of alignment, hence the noise the machnie is making.
Please ensure that the soleplate has been correctly positioned and that the brush bar is aligned correctly before attempting to use the machine.
If this does not resolve the problem, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Dyson Customer Service
Feb 24, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Hoover Savvy has limited suction when cleaning the floor and carpet
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Jan 03, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Less suction and high pitch whine while vacuuming
most any vacuum repair shop will be able to remove the obstruction causing the problem
Jul 29, 2017 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum Logo
42 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
