Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Dishwasher trips circuit
Hi, i have the exact same problem described, and i am thinking that it may require a replacement drain pump. Can you tell me if this is likely to be the case and how to go about changing the pump?
Many thanks for any assistance offered.
Regards,
Russell.
Buy paper pants
Posted on May 09, 2011
  • 3 Answers
Had the same thing and it was a minute hole in the corrugated hose that the water escaped through and caused the machine to trip.
Posted on Sep 05, 2008
Asko dishwasher D1760 tripped the power on drain function, replaced drain pump then worked ok. Next day dishwasher started making a very loud noise when washing then tripped power. Thoughts?
The replacement pump may have failed early on. Something other than the pump may causing failure, such as ingestion of some kind of destructive material.
Feb 11, 2017 | Asko Dishwashers
When I push auto and start the lights go on and the time, but then it goes off. Why?
Hello. Is this unit less than 1 year old? If so, anything defective is covered under the warranty(parts and labor). After 1 year, certain parts are covered, however, no labor is covered. Make absolutely sure the door is closed properly--there is an internal door switch that must be closed(tells the main board it's okay to start the cycle) or nothing will happen and produce the exact symptom you describe. Next, the unit could be experiencing an error condition causing the shutdown. Make sure the water supply to the dishwasher is turned on(and always run the hot water in the sink before starting the dishwasher to ensure hot water gets to the unit). Next, do you hear the drain pump working? A lot of dishwashers turn on the drain pump immediately to remove any standing water in the pump before letting in fresh hot water. If the drain pump is jammed or clogged, you might hear a soft humming sound only(from the motor trying to spin) and then the dishwasher will shut down due to it detecting a malfunction. Check the float switch in the tub to make sure nothing has gotten underneath it(ex. a spoon or fork can become lodged underneath and the dishwasher thinks there is already water inside and won't fill) I hope this helps you!
Oct 12, 2015 | Maytag MDB4949SDH MDB4949SDH Dishwasher...
Bosh SHY56A Dishwasher - Loud Pop and Smoke While
Hey Matt,
Dishwashers are not that complicated.. Turn off the breaker, pull the machine out - away from the wall..(there will/should be at lest two screws in the top edge holding it to the counter.. remove them first.. then pull it out until you can turn off the water supply.. When you are able to completely remove the washer, you should be able (possibly)to see what happened.. Check to see if the washer arm (inside the washer) will turn, if not.. replace the motor.., check to see if the pump belt will turn?.. it could be the pump drive motor or the pump its self..(remove the belt), then see if the motor will turn, check to see if the pump will turn.
.. White smoke makes me think that the belt was turning and the pump NOT turning..that will cause the belt to smoke.. and smell like burning rubber..If the pump will not turn. you have found t he problem... Also ..Check to make sure there is not a knife or some other object lodged in the drain or pump
NOW -- With all this.. Sometimes REPLACING the machine is actually cheaper than repairing the old one!!! Your wife deserves a NEW one!!
Jun 28, 2017 | Dishwashers
Power trips 1-2 secs after on button pressed. Been
hi - i would tend to think that theres an electrical problem with the machine, as most dishwashers will start with the drain operations before commencing any cycle - the drain pump may well be the cause..
Cheers
Jul 08, 2011 | Electrolux EIDW6305GS Builtin Dishwasher
Water does not drain,how do I access the pump
Hi jolanda03,
Remove the Top Panel, fastened by 2 screws at the back, Then remove the right Side Panel, you should see the Drain Pump attached to the sump. To test it, you could attach direct power to the two pins on it (Alternating current, so position of connectors unimportant). If it works, it could be either that it is not receiving power from the PC Board, or the sump is clogged inside (Filter).
Hope this helps, if it did please rate with 4 thumbs up. A testimonial would be nice too. :-)
Apr 21, 2011 | Dishwashers
Dishwasher keep tripping power from circuit panel?
That could be either the motor or the heating element...
You will need to check it out with an Ohm meter to tell for sure what the exact cause is...
heatman101
Aug 18, 2010 | Jackson 25 in. TempStar HH/GPX...
Dishwasher stops after 10 minutes inlet/drain light flashing
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Dishwasher not draining
Hi. this may be caused be several issue that i will discus below. Kindly read over the list that will describe several issue that may be apparent. replace any parts that corresponds to the issue you are having.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
May 28, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
94 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
