Samsung error code 8e
8e
what is it plse
3 Suggested Answers
Maanita
  • 1142 Answers
SOURCE: Spin cycle wont work and
It doesn't pump or spinIf it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • Posted on Aug 05, 2008
    theytsg
    gsjkdjd jskkkd jskdlkx jxkdghx xkoxb zjxknjxj
    Posted on May 23, 2014
    Showing code 8E
    This error code means the ice maker sensor is bad. On Samsung the sensor is part of the actual ice maker which you can find here.
    Ice Maker For Samsung Refrigerator Model RF323TEDBSR
    Sep 26, 2015 | Samsung RF323TEDBSR 31.6 cu. ft. French...
    Troubleshooting kenmore elite model 592-49496 Signal 8E comes up
    check main board (PCB ) look at the components , if you find any blackish thing or worn , check it with multimeter upload images , that would help us to guide .
    Regards
    Dec 31, 2014 | Kenmore Washing Machines
    Fault error code 8E
    an 8E or 8E2 means - Sensor problem.
    Feb 19, 2014 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
    8E error code on samsung top load direct drive washer
    Samsung has us replace Mems sensor, main harness and user interface board. They do not have away to test the mems sensor in the field.
    Dec 09, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
    Samsung refrigerator error code 8E
    8E = OVER CURRENT ERROR
    IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
    IPM: Integrated power module. The IPM controls the motor.
    If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
    If the motor stops working, in one direction ten times, "8E" Error is displayed.
    During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
    Nov 23, 2012 | Samsung RS265TDRS Side by Side...
    E8 front loader washing machines
    OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
    HOWEVER, the UK White goods website says:
    E8
    Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
    You can find more about your Samsung Washing Machine error codes at:
    http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
    or
    http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
    Jun 21, 2011 | Samsung Washing Machines
    My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
    OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
    If the motor stops working, in one direction ten times, “8E” Error is displayed.
    During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
    would advise calling a tech... hope this helps.
    Oct 25, 2009 | Washing Machines
    E8 error code
    8E - OVER CURRENT ERROR
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    May 02, 2009 | Washing Machines
    Error code 8E shows up just into the wash programme
    8E is an overload or over current error code.. try unplugging it for a few seconds and plug it back in.. if it continues you could have s short in power distribution block on the board.. I would recommend if it continues for you to call a tech im sorry to say.. Good luck
    May 26, 2008 | Samsung Washing Machines
    Washing Machines Logo
    803 people viewed this question
    Top Washing Machines Experts
