Question about Epson Stylus C43SX InkJet Printer
Paper feed problem
When i start to print...it doesn't print the whole page.. it only print at the top page.. the paper feed is unusual.. how can i set it to normal paper feed
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    What Operating System are you using?
    Worldvet
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Try a test print first, from control panel/printers
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
When I print a multiple page document on tear paper roll, the first page prints correctly but the pages after that start printing too near to paper tear size or up to paper tear size. What should I do
Sounds like your top margin is not either not set properly or your documents do not have page feed command at the end. Are you sure you have the correct driver installed?
Nov 23, 2014 | Epson Dot Matrix LQ-2090 Printer
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
Printing doesnt start at top of page
Sure the paper is correctly document may be the printer thinks the paper is metric instead of inch check the printer setting
Jul 12, 2012 | Minolta magicolor 2400W Laser Printer
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
HOT TO ADJUST THE TEAR HEIGHT ON A MICROLINE 490 WITHOUT USING THE SETUP DISC
If you are using regular letter size continuous printer paper, load the paper normally with the machine turned off. You can even turn the knob to feed the paper through, it doesn't matter how far. Turn the printer back on and press "PARK" button. Then press the "FF/LOAD" button and when you begin printing it will automatically print at the top of form (TOF). If the TOF ever gets thrown off you can press "LINE FEED" until the tear is where you want it and press "SHIFT" > "TOF" to back back to the previous page (or top of form).
Simply put, pressing "PARK" then "LOAD" should set the tear where you need it.
May 20, 2011 | OKI MICROLINE 490 Matrix Printer
After a paper jam my Canon MP700 now ejects a blank page then prints a page (perfect) the ejects the next page. Any ideas!!!!
It means the gear timing for the paper advance is off. A fairly quick fix in a shop, you need to remove all top covers and loosen the paper drive and set the gears on the timing marks again. In rare cases the plastic stud for the timing gear breaks out of the frame and you need a whole new feed assembly, about $40.00
Jan 13, 2010 | Office Equipment & Supplies
Paper feed jams
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
Paper Feed
The problems are particularly frustrating if it's a Word 2007 document that you're trying to print. Open the document, go to the Page Layout tab, select Page Set Up > Paper and set your printer source to whichever tray you want. Apply to the whole document and voila !
Apr 08, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Epson Stylus C43SX InkJet Printer Logo
80 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
