Question about ASUS P4S800-MX Motherboard
PC wont boot, not even to bios
3 GHz cpu, 2GB ram.
I have tested the cpu in another m"board and it works okay.
I have tried replacing the ram, trying another PSU.
I am thinking the M'board is shot, but i have a mate with 2 ASUS P4S800-MX boards and he has the same problem. Coincidence or what?
  • 50 Answers
Maybe the mobo is shot for u and he has his PSU shot.......Check for any burnt smells from the mobo. See if the cable from the PSU is properly connected to the mobo. Try removing all drives like graphics cards, RAMS one by one and see if it works.
Posted on Aug 18, 2008
BIOS says 3GB RAM, Properties says 2GB RAM
You may want to flash your bios on the motherboard if there is an update. Windows XP Pro will support up to 4GB of RAM.
Feb 20, 2013 | Microsoft Windows XP Professional
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
Won't start - tested power supply - it is good - removed cards and drives still nothing. Board looks okay - no holes - canisters are flat - what next?
re-seat the memory - how did you check the power supply - its fan working does not mean it functions properly - if you have spare try that one.
Sep 01, 2009 | E-Machines T3085 PC Desktop
I have been having some boot problems into windows with my p4s800 mx motherboard. I have purchased it with a 3,0 ghz cpu and put it together yesterday, after which I tried to boot it. It works on lets say...
The BIOS utility probably has a setting for the BIOS to automatically detect and maintain your CPU's clock speed. Make sure that is ON or ENABLED. Another probable reason for the failure may be your RAM settings. Again, use the automatic detection of your memory's speed and latency settings.
One last probable reason may that you may be using different kinds of memory SIMMS or DIMMS. Some boards are very finicky and will not work efficiently with different types, if at all. Others will simply not work.
Aug 16, 2009 | Computers & Internet
Asus P5Q-VM CANT BOOT
CPU Should work with board.Try removing cpu and replace in socket check for bent pins if all is well..reinstall.make sure to use pad or silver paste and reinstall fan.rebootRichardm69
May 05, 2009 | ASUS Computers & Internet
I put my 3 0 ghz cpu in my Gateway Intel 850 Socket 478 ATX Motherboard no video from agp is new board with 2x 256 rimm pc 800 pc seems to start all the fans as well new power supply 512 ati vid card but...
Remove the BIOS recovery jumper near the battery on the motherboard and attempt to boot. If the system displays a startup screen, replace the jumper on pins 1 and 2 (pin 1 will have an arrow by it) and configure your bios appropriately.
Mar 16, 2009 | Computers & Internet
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
PC Freezing !
Update BIOS to P25 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&Inst=Yes&ProductID=948&DwnldID=10130&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
Reset BIOS to default settings.
Check CPU Temperature, Prescott CPUs run hot.
If board is under 3 years old and was a retail box package, it will be under warranty, contact Intel.
Jun 29, 2008 | Intel Motherboard
MSI P6NGM won't BOOT
You should only hear 1 beep. That 1 beep is power on self test, known as P.O.S.T.
That loud flat line sound (And I'm pretty sure about this), was you're CPU. Just because you ran & passed the stressed test is nothing compared to running the system under load? That's why when you put in you other memory nothing changed. If you hadn’t mentioned you clocked up the FSB I would have come to the same conclusion hearing the loud flat line statement.
Can you test the CPU in another board? That is about the only way to be sure it's not the CPU. Memory does not make that kind of sound. Memory makes short & long beeps.
You can try clearing the cmos/bios by going to pg. 2-18 in you're user manual. This will reset the bios back to default settings & cross you're fingers!
If I can be of more service, just post back & let me know how thing go.
Good Luck!
Mike
Apr 25, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
ASUS P4S800-MX Motherboard Logo
171 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
