Question about Canon imageRUNNER C3200 Color Printer
Canon iR3100CN error code
Machine starts up normally and the error code shows
  • Anonymous Oct 25, 2008
    error code E00002-0102
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Do you have the installation or user guide for this printer?
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
SOURCE:
Copier ir3100cn when switched on display error code e000805-0003 what is this problem ?
I believe this is a problem with the main cooling fan in this machine, check this is rotating properly, and if not, it will need to be taken out and tested, and then replaced it is, indeed, fautly.
May 27, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
My canon ir3100cn displays "finisher
My canon ir3100cn displays "finisher can not be used" with on screen. i'm using saddle Q2 finisher. it doesn't move at all.
Sep 03, 2011 | Office Equipment & Supplies
Canon IR3100CN error message E000732-0001
Found a defective cable (FH2-7036-000) between Reader & machine causing error code
Sep 14, 2010 | Canon imageRUNNER C3200 Copier
Canon ir3100cn giving me error code E000020-01a9. how can I go about it?
Hello luvmor. The code means the that when the copier tries to calibrate its colors (gradation) it cant get the yellow to calibrate.This almost certainly because the yellow drum has reached the end of its life.On this machine,it is not as simple to replace the drum unit as it could or should be.Newer machines are far easier to perform a drum replacement.I would have to recommend a trained technician to perform this procedure.
Apr 21, 2010 | Canon Office Equipment & Supplies
Showing error code E000020-01a9 on IR 3100CN
this code is for the density of the yellow toner, most likley has a bad drum.
Aug 13, 2009 | Canon Office Equipment & Supplies
Canon IR3100CN E000070-0002 During start up the code pops up and the copier don't work.
you have a broken ITB unit,
its a pretty common error code on these machines, you need to replace your ITB frame and it prob has broken the belt also
Jun 04, 2009 | Canon imageRUNNER C3200 Copier
E000733-0001 the err means I have the same problem, the same error code: E000733-0001 on my Canon IR3100CN. I cannot pass to service mode...After I switch off & on, the display shows me the same...
E733-0001 Error Code
E733 and machine locks up with progress bar at 98% on boot up?
I would refer this error to a qualified service Tech.
Deals with replacing DC controller, Main Controller and Boot Rom as a set. Also, mention of replacing the Switching Regulator PCB Assembly if the previous failed to resolve.
May 27, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir3100cn
check your itb home position, are you sure for that error # e0072? maybe e0070
May 21, 2009 | Canon imageRUNNER C3200 Copier
Error code
HI
Machine error E0020-01a9 is developer problem
Dec 13, 2008 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Color Printer Logo
181 people viewed this question
Clive
Clive
old marine
old marine
Ekse
