Question about Refrigerators
Fisher and paykel E240B refrigerator freezer has just started beeping 11 times when i open the door and is not freezing in the freezer cold enough
I called F&P customer care when my fridge did this, and apparently 11 beeps means the compressor has failed. I hope you got someone to fix your fridge! I decided to post a solution as I couldn't find one online anywhere!
Posted on Jul 01, 2009
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Why did door alarm suddenly start going off every time I open the fridge or freezer?
Hi Christine.
When your F&P beeps, it's indicating a fault code - count the beeps which will relate to a fault code. 17 beeps would indicate an issue with the freezer fan.
Could be the reed switch (door switch).. amount of beeps will indicate the fault code.
Dec 14, 2015 | Fisher and Paykel E402BRXFDU Bottom...
Why does my fisher and paykel active smart fridge/freezer keeps beeping when I open fridge? As if the fridge has been open for a long time?
Does the beeping start immediately or does it follow the designed timing as stated on page 12 of the manual? You would have to check with the manufacturer to see if the feature can be disabled. Page 12 of Fisher Paykel Refrigeration User Guide ManualsOnline com
Mar 08, 2015 | Fisher and Paykel Refrigerators
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel E402B beeping, freezing symbol flashing, crisper bins freezing.
sounds like a sensor faulty will need a tech to recify the problem.
Nov 29, 2012 | Fisher and Paykel Refrigerators
Hi friend has a fisher and paykel refridgeator and its sounding an alarm of one beep and then 3 or 4 long beep followed by a short beeps then then a single beep its a top freezer model and the refrigeator...
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 11, 2010 | Fisher and Paykel Active Smart E522B...
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
739 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
