Question about Philips Televison & Video
How to re tune a 20 pt 4673/75R Tv without original remote. Thanks John
  • midcity41 Aug 19, 2008
    Thanks a heaps.Well done.J
  • 44 Answers
That has a PLL tuner that retunes everytime you change channels so there is no fine tuning.
If it is out of tune, then the tv needs repair. If you need to switch from Air to Cable or Cable to Air and then Autoprogram, that would be in the menu.
The model number does not appear in my Philips cross reference. Generally, the Menu is a seperate button or pressing the Volume Up and Down together until the Menu displays.
Posted on Aug 19, 2008
Can I reset the lamp timer without the original remote
No, original remote is needed for this--a universal will not cut it.
If Panasonic the remotes are usually reasonably priced and have all the features you really need.
Mar 26, 2012 | Panasonic PT-50DL54 50" Rear Projection...
My sanyo tv doesnt have the remote and i need t adjust the screen so that i can see the whole picture
U can't do these kind of adjustments without the tv original remote sorry.Try website like Remotes.com to buy the tv original remote to used.
Aug 31, 2011 | Sanyo DP32746 32 in. LCD Television
Setting up a Harmony 659 universal remote without original remote
Hi. Chances are the commands for your TV are already in the Harmony database. All you would need to do is add the TV to your remote and it should work.
1. In the software, click 'Add Device.'
2. Enter in the model number, etc.
3. Update the remote
May 07, 2010 | Logitech HARMONY 659 Remote Control
Toshiba Regza tv was in storage we took it out and can't find remote is there a way to tune without it? Thanks
Yes,must use the manual control on the tv itself.Very trouble some.Buy a new exact remote on website 1-800-Remotes Factory Original.
Jan 16, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Left side and right side are blury.
With projection sets, there is typically several settings for which you can display an output. You probably have a "wide" or "stretch" as a setting for the tv. What you want is normal, or some setting which doesn't result in a stretch. Widescreen projection tv's try to stretch 4:3 output into the widescreen setting, but usually this just results in the middle being in focus, and the outer 20% to be stretched on each side, bluring the edges.
Try to manipulate as many "tv settings" as possible. For most sets this is only available with the original remote. If you don't have the original remote, changing these settings could prove difficult.
Apr 05, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Toshiba 2100TB tuning without the remote control
If you are sure, that there's no way to do it manually on the TV, there are only two solutions: buy a new remote control according to your TV set model (sometimes it's hard to find) or buy a universal remote control
Jan 30, 2009 | Televison & Video
How do i tune tv channels?
I am afraid thatyou need the original remote to access tuning universal remotes will not give you this option. An original remote will probably be very expensive check with your local TV dealer.
SUPER8
Jan 05, 2009 | Televison & Video
Sound
The SAP must be turned off and you must have the original remote apparently. I would do a search for Orion customer support and get a remote.
Feb 10, 2008 | Orion STV2763 27" TV
Tuning
John,
Enter setup from the front panel or remote. Go to auto tune and select it. from here your tv will select the channels available on your cable line or from off the air. Wala your tv is tuned.
Jan 21, 2008 | Panasonic PV-C2062 20 in. TV/VCR Combo
Remote Code for universal GE remote
Use your sky remote you can tune it to your TV, all the buttons will be in the wrong place so you will have to play around with it.
It worked for me.
John
Nov 09, 2007 | Durabrand DU1901 TV
Televison & Video Logo
145 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
