Question about Bosch Refrigerators
My Bosch upright fridge is not defrosting & has a wall of ice on the back. The fan does not appear to be working either. Is that the problem? - cant remember how often I see the fan working now!Thanks
  • Pattie 48 Aug 19, 2008
    Thank you so much for your help!
    Will try your suggestions. Very helpful.
    Kind regards.
    Scholar:
  • 111 Answers
I kind of doubt that the fan is the problem. On my refrigerator, when it goes on defrost, the fan shuts off. They don't want it blowing heated air on the milk. Yours might be different.
I don't know this particular frig, but evidently the defroster doesn't work. Perhaps the fan doesn't work also, or perhaps the fan would work if the defroster were fixed.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
I think that when the defrost heater is turned on, then the fan is likewise turned off. The defrost thermostat, I think, is doing it's job, letting it cool again. But the timer is stuck. Or something???.
Hope you can fix it.
Posted on Aug 19, 2008
SOURCE:
My whirlpool gold freezer is working but my fridge is warm I have an upper fridge and freezer is on bottom how can I fix it
all the machine does is the evaporator coil in the freezer gets cold,there's a fan in the freezer that blows the cold air from the freezer up into the fridge section and that's it,so if your fridge is warm you either have a bad evap fan motor or you could have a defrost problem,check to see if there's any ice or like snow on the back inside wall of the freezer,if so you have a defrost problem and you'll have to see what part is bad,if it is a defrost problem,you can shut the machine down or unplug it,take the food out of the freezer and if you can remove the back inside wall so you can melt out all the ice on the coil and air ducts,this will give you like 10 to 12 days to fix it or call someone in to fix it before the coil freezes up again,you can use a hair dryer to do this,or there could be a damper inside the top of the center back wall,you'll see slots in the top of the tower on the back wall,if there's a damper the damper door might be closed not letting any air in,next time send the full model number off of the fridge so whoever answers you can see what you have,if the freezer is on the bottom usually if you open the fridge door or the right french door,look up on the right wall near the ceiling and you should see a tag,if not there look on the other wall or ceiling they used to be on the right wall but on some of the newer models they moved the tag, nice guys lol.so open the freezer door,listen for the fan,if you don't hear the fan that could be your problem,check the back wall for frost,you could have a defrost issue or if there's ice on the back wall and the ceiling the door could have been left open,common problem with bottom mounts,if so if you google the model number you can find how to manually put the fridge into defrost,this turns the heater on in the freezer to melt the ice off of the coil,you can then get in there with a hair dryer and help melt it out,when you don't see any water dripping down and you can see it through the slots that are cut in the back wall of freezer your all set.the problem is the air ducts are frozen up and the air can't blow from the freezer and into the fridge.hope this helps you out but without a model number this is the best i can tell you.
Nov 23, 2017 | Whirlpool Refrigerators
TOP HALF OF FRIDGE COVERED IN ICE AND FREEZING FOOD/DRINK
I have had this problem in the past. You will need to get the automatic defroster fixed or take all products out of freezer part of fridge. Remove back panel of freezer unplug from wall let defrost. put fan in front of it to speed proses. usually an hour or so depending on how badly frozen it is. good luck.
Apr 10, 2013 | Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Tempreture on fridge too high ice build up in fridge mahes noise like a tractor
Your automatic defrost cycle may not be working. Feel the walls inside and if they are hard solid you have ice build up and the fan is hitting the walls or ice making the noise. Unplug your fridge for 2 days and let the ice in the walls melt. Put towels on floor to catch water. Plug it back in and it should run fine for a couple of weeks until the ice builds up again. You have a bad timer and it isn't letting the defrost cycle come on. Defrost cycle are heating elements that melt the ice build up and runs about 10 mins once a day or so. This will give you time to check if an afforable repair can be done or a replacement fridge.
Jul 11, 2010 | Samsung Refrigerators
The top half of the upright freezer is totally thawed but the bottom is frozen. I need the whole thing to freeze.....
Check for ice on back wall if iced up check defrost heater and defrost timer also check and besure evaperator fan is working check wireharness on heater, timer, and evap. fan motor.Sounds like you have a defrost prob. Turn off for 24hrs to melt ice turn unit back on if it works for a few days then ices back up you have a defrost prob.
May 16, 2010 | Freezers
Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Oct 28, 2009 | Refrigerators
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Bosch fridge not cooling freezer fine
if back wall of freezer has ice or thick build up you may have a defrost problem or if not the evaporator fan motor could be bad, not moving cold air from freezer to refrigerator.
Mar 14, 2009 | Bosch Refrigerators
Fridge freezing up on back wall of fridge not defrosting
is freezer fan working?remove freezer back wall put frig. in defrost,watch freezer to see if the heater is melting the ice,if not wait 20 minutes till freezer out out of defrost and fan comes on,if it does you have a bad heater and bimetal switch (the little silver round thing clipped on coils,let me know-mike
Sep 22, 2008 | Refrigerators
Fridge not cold
ice build-up on the back wall indicates a defrost issue, check the defrost items. check the defrost timer, the defrost heater and the defrost thermostat, if you need more details let me know.
Apr 02, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Refrigerators Logo
282 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
