How dow you get the child lock off - Televison & Video
  • 927 Answers
Good Day, debek;
To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds.
Good Luck, big IRISH.
Posted on Aug 19, 2008
Door not unlocking Fisher Paykel front loader Wh60f60w. The cycle appears to have completed but the door remains locked well beyond normal lock delay. Is there a manual release?
Have switched this on?
Child-proof lock
? You can protect the appliance from being tampered by activating the child-proof lock.
? When activated, no change can be made to the programme running.
To activate the child-proof lock:
1 Press the 1st and 2nd additional function buttons for 3 seconds.
2 The "C ON" (child lock is activated) symbol appears on the screen.
Note: the child lock symbol will also be displayed whenever any button is pressed while the
machine is child-locked.
3 The child-proof lock lamp on the programme follow-up indicator will light up when the childproof lock is activated.
To deactivate the child-proof lock:
2 The "C OFF" (child-proof lock is deactivated) symbol appears on the screen.
3 The child-proof lock lamp on the programme follow-up indicator will go off when the child-proof
lock is deactivated.
Apr 01, 2017 | Fisher Washing Machines
How to turn off the child lock on a dryer
This information is from the manual:
Child Lock can be used to prevent your children from changing options on control panel while the dryer is running. When child lock is enabled, all the buttons will be locked and Child Lock glows. To enable Child Lock, Press and Hold OPTION for 3 seconds, A single beep tone is heard and Child Lock is displayed on the status window. To disable child Lock, press and hold OPTION for 3 seconds again.
May 27, 2014 | LG DLE2514 Electric Dryer
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 | AEG Dryers
Child lock is stuck on and athe dryer will not turn on. How do yoiu turn off the child lock?
HI!!
Child Lock can be used to prevent your children from undesirable use on control panel while the dryer is running. When Child Lock is enabled, all the button will be locked and Child Lock glows. To lock Child Lock, Press and hold Rack Dry for 3 seconds, A single beep tone is heard and CL is displayed on the status window. To unlock Child Lock, press and hold Rack Dry for 3 seconds again.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 03, 2011 | LG DLG5988 Gas Dryer
I have the 2010 Samsung Washer/Dryer 10kg and it is stuck on child lock. I can not get it off. Help?
Follow this instruction............. ACTIVATING/DEACTIVATING
If you want to activate/deactivate the Child Lock function, press the Soil Level and Signal buttons at the same time for 3 seconds.
How It Works: 1. "Child Lock" can be activated while your Washer is running. 2. Once you activate "Child Lock", all controls (except for the Power button) will be locked until you deactivate "Child Lock". 3. The Child Lock button will be lit while it is in effect. When buttons, other than the Power button, do not respond, please check if the "Child Lock" function is on.
Hope this helps u out!
Nov 17, 2010 | Samsung Washing Machines
My TV is on child lock how do I unlock please
  1. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
  2. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
  3. Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Read more: How to Unlock the Child Lock on a TV ' eHow.com http://www.ehow.com/how_4510749_unlock-child-lock-tv.html#ixzz12VdKs6Bt
Oct 16, 2010 | Televison & Video
How to remove child lock on rear doors?
Show me how to take the safety child lock off switch also I need a picture of this location on the door
Jul 20, 2010 | 2008 Chrysler Town & Country
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
Child sign in window of microwave ,cant start it panasonic
On my NN-L738BA there is a Child Lock feature.
You set the child lock by pressing the Start button 3 times.
If the Child Lock is enabled it displays the word :CHILD".
To disable this feature on my microwave the manual says to
press the Stop/Reset 3 times.
Check your manual for the Child Lock.
Mar 06, 2009 | Panasonic NN-S541 Microwave Oven
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
