Question about Dryers
INDESIT CONDENSERDRYER. WATER LIGHT ON
I HAVE A INDESIT CONDENSER DRYER. I HAVE EMPYTIED ALL THE BITS THAT NEED EMPTYING BUT THE LIGHT IS STILL ON EVEN AFTER LEAVING IT OFF FOR A WHILE AND THEN RETURNING IT ON THE LIGHT IS FOR EMPTYING THE WATER
If the machine is 9 years old or more it is not worth repairing!
Buy a new machine will save you a lot of energy and money!
If it is out of warranty, call A&E factory service for repairs and they are open 7 days a week! 1-800- 905-9505
Neil
Posted on Aug 21, 2008
SOURCE:
My Indesit idca8350 tumble dryer keeps stopping mid cycle and all of the top lights flash and the clean condenser light stays on. If you switch it off and on again at plug it resets it.
Remove the condenser and clean it. They normally just need a lever to be unlocked and the whole condenser will slide out of the machine.
Sep 29, 2018 | Indesit Dryers
It says the water needs emptying but it is empty
After reading about various dryer problems / solutions it seems others have had this same problem. It could be that a smaller resevoir which houses the sensor connected to the water collector is full and it's valve may be blocked with lint. It can be solved by getting to the valve and removing the lint. You may need to remove the valve itself. Hope that helps. Good luck.
Oct 20, 2012 | Candy CDC266 Dryer
Water sensor light keeps coming on even tho tank empty have checked hoses and cleaned large filter at front
try cleaning out the condenser unit, instuctions are on pages 2 and 3 of your manual, if you dont have it download it from the indesit website.
fluff and old stuff gathers in it, if you leave it too long it will burn out the thermostat
instructions below.
Step 1
Open the condenser cover
- grip the handle and pull
towards you.
Step 2
Remove the condenser by
turning the 3 catches, then pull
the condenser towards you. (It is
normal for some residual water
to be left in the tubes).
Step 3
Clean the condenser with running
water over the rear side to
remove any fluff deposits.
Step 4
Replace the condenser unit;
make sure that the unit is
securely in place, that all 3
catches are fixed and that the
position arrows on the front end
of the condenser are pointing
upwards.
Nov 15, 2010 | Indesit IS70C Electric Dryer
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Dec 05, 2009 | Hoover Dryers
Indesit condenser tumble dryer water light always on even though container empty
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
Oct 06, 2008 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Feb 24, 2008 | Dryers
Indesit IS70c condenser dryer
CHECK PUMP AND FLOAT AT REAR OF DRYER EITHER PUMP IS BLOCKED OR PIPE FROM PUMP BUT MAKE SURE THE DRYER IS UNPLUGGED WATER AND ELECTRIC DO NOT MIX,
IF YOU ARE UNSURE WHERE TH PUMP IS GET A QUALIFIED ENGINEER
Dec 25, 2007 | Dryers
Dryers Logo
143 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
