Question about NEC MultiSync MT1050 Multimedia Projector
Display Stops after 5mins
My NEC1050 stops Lamp after 5 minutes. It is put in economic mode. During startup power led is steady green and Status led is blinking green.
After about 3 minutes status led is steady green which indicates projector is running in economy mode. After about 5 minutes from startup the status led bocomr flashing red for 4 minutes off and 4 minutes on. After about 1 minute the fan stops blowing and unit becomes ready to start. It happens every time I start the lamp. Can any one help me in this regards. I do not have service manual as it is not available in net.
Regards
Manik
  • 4 more comments
  • ManikKolkata Aug 18, 2008
    the link contains only user manual not service manual.
    Regards
    ManikKolkata
    Dear sir,
    This thing is repeating. So by stopping for 1 minute every 5 minutes I have been able to run it for nearly two hours. I did not tried more because this will reduce the life of the lamp. I have got soldering iron, DVM etc, but due to want of a service manual I did not try to repair the machine. So what I need is Service manual of NEC MT1050 and some guidance to use the maual.
    Regards
    ManikKolkata
    ALREADY i TRIED WITH ADDITONAL VENTILATION BUT WITHOUT LUCK
    All I nedd a service manual preferably from NEC. But NEC website does not provide any support, other than user manual.
    Regards
  • ManikKolkata Aug 22, 2008
    Though my problem was not resolved, but I got the service manual from ravco which I did not get after many searches. Thank you
  • ManikKolkata Aug 29, 2008
    I am back again. With the service manual in hand, I opened the MT1050 lamp cover then front cover and top cover. Everything inside the projector seems to be OK. The only tempterature sensor I could locate is located on the main board and seems to be fine. I arranged for additional ventilation but the projector shuts down after 5 minutes and can only be started after one minute. I want to know whether there is any other temperature sensor or not.
    Regards
    Genius:
  • 2,920 Answers
Make sure the filter is cleaned out so the fan can breathe,,,otherwise it makes it hot and shuts down on you
Posted on Aug 18, 2008
  • 199 Answers
As a follow up to Benimur's post and if you are considering a DIY, the following might be of further help:
  • a cleaning of the inside with the use of a can of compressed air and a vacuum cleaner;
  • source of Service manual;
  • correct user's manual;
  • often the problem is heat related or sensor(s) erroneously reading false temperature;
  • to my knowledge the NEC MT1050 uses a JED T460 projector controller with several smaller PCBs for various sensors. A possible source of parts.
Cheers.
    Genius:
  • 1,665 Answers
Assuming Warranty has expired;
At link below is a list of merchants and service centers that repair projectors. To get merchant pricing and policies for your projector repair, select your projector brand before you click on the merchant or service center.
http://www.projectorcentral.com/NEC-repair-suppliers.htm
    Scholar:
  • 163 Answers
It seems power supply overheating problem (must be checked). Try to use an external ventilation to keep lower temperature and see if different result.
  • 157 Answers
Hi.
Clean the dust around the lamp. Sometimes dust may interfere with the picture produced by the lamp and the cooling mechanism of the lamp. After you have cleaned, take the lamp out and put it back in, the lamp could be loose. Check for loose connections of wires aroud lamp. If the projector has a reset button, press that and see what happens. If all fails, you may need a new lamp or i would advise you let a technician have a look at it if its out of warranty. If you are familiar with electronics, you may wanna have a look at the board and check if the soldiering is still ok.
Hope this helps
Cheers
Jigsaw
  • John Smith
    John Smith Aug 18, 2008
    P.S. your service manual may be here
    http://www.ravco.us/service.php
    Brigadier General:
  • 6,966 Answers
Initially, pls check the filter and vent ports as well as the fan. Verify that tjhey are not clogged and that the fan is providing adequate ventilation. Should problem persist, try to locate a reset button if available and press on it. Alternately, unplug the unit from the mains for about 15 minutes to try and revert back to factory default.
If above fails, further diagnosis require familiarity with electronic components and circuitry, use of a DVM and a soldering iron. Pls post back if your are considering a DIY (do-it-yourself). Otherwise, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Aug 18, 2008
    Hi again,
    Appreciate the postback and additional information. As to your concern, here is a Service Manual
    Genius:
  • 1,847 Answers
You can get the manual from this link..
http://www.support.nec-display.com/dl_service/mlt150z_en.htm
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
Dear Sir, I have a NEC LT 260 K Lcd projector. The lamp of the lcd was busted.I replaced it with a new lamp. After replacing the lamp the lamp is not lighting when projector is put ON, I think the...
the clicking sound hopefully is the high voltage trying to start the lamp, but for some reason there may be a connection problem between the lamp and the projector power supply.
take the lamp out.
look at the lamp and check that the 2 connecting plugs are ok.
then look inside the projector at the power sockets that connect to the lamp (when it's installed).
check that the pins are not damaged or pushed down too far to prevent the lamp plugs making a proper connection with the power sockets in the unit.
Jul 01, 2011 | NEC LT 260K Multimedia Projector
How to unlock motorola 3G A1000
Try this: Might work.
Connect the phone to a powered Clip. Phone display should give "USB cable connected" message.
Press UNLOCK button on the Clip.
Phone reloads. Within 5-10 seconds phone display gives "Waiting for PST" message.
Press 1 and 2 keys simultaneously in upper part of the handset. The phone enters boot mode (if you don't press these two keys during "Waiting for PST" message, the Clip will give red E/G led and you will have to start with step 1 again).
After 1 and 2 keys have been pressed E/G green led will blink and the phone reboots. Meanwhile E/G will give frequent green blinking and phone will turn on.
Do not disconnect cell phone from Smart-Clip while green led indicator blinks!
Green E/G led glows. The cell phone is unlocked.
Axxx/Exxx/Vxxx unlocking noteDon't unplug cable right after phone reboot, wait until E/G led stops blinking!
good luck.
kc
Mar 11, 2011 | Motorola Cell Phones
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
TV was working fine when we went to bed Monday (August 30) night. Got up the next morning and turned it on. It appeared it was going to come on, the green light flashed and then the lamp indicator light...
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A
Sep 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Printer Model : hp LaserJet 3020 OS : Windows XP(32 bit) Problem : When I did my last firmware update I interrupted by pressing the cancel button on my printer control panel as it showed "Printing...
Never ever touch the printer while upgrading the firmware.
You now need to replace the formatter
  • DO NOT power cycle the printer or the PC during this process or the printer may become unstable and or unusable without further attention from HP . The firmware update can take up to 5 minutes to complete. Please be patient.
  • During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display "Printing Document" and will change to "Erasing". After a short while, the LCD display will change to "Programming". After a short while, the LCD will display "complete : )" and the "Ready" LED on the printer will be flashing. The printer will automatically power cycle to reboot and will make noises similar to power on.
Jan 28, 2010 | HP LaserJet 3020 All-In-One Printer
Nec projector vt440 wont turn on
Hello. First check the lamp! From your description, it sounds like the projector is telling you that the lamp needs to be replaced. In "eco mode", when the power is green and the status is steady orange, that is the error message. In "high brightness mode" the status will be steady red. Hope I helped you.
Feb 22, 2009 | NEC MultiSync VT440 Multimedia Projector
Coleman 15k will not come on
Here is the troubleshooting guide for your unit. Hope this helps.
TROUBLE SHOOTING GUIDE
TROUBLESHOOTING
Symptom Remedy
1. Remote does not turn on system
- Check and replace remote batteries if the display fades while
any button is activated or no display is present. - Point remote towards IR receiver during transmission. 2. System does not turn on, no green LED & no beep
- Check wiring. (see "installation instruction")
- Check modular cable to receiver.
- Check diagnostic LED status in the upper unit control box.
3. System does not turn on even when receiver green LED is on.
- Low or over voltage condition, check diagnostic LED status in the upper unit control box.
4. Fan runs but no cold air.
- Evaporator temperature sensor reaches low limit, defrost mode.
5. System runs continuously in the cool mode
- Remote was set for "I feel" mode and is left in a heated environment (sun etc.)
6. System runs continuously in the heat mode
- Remote was set for "I feel" mode and is left in a cool environment
1. Diagnostic LED (green)
(Note: Located on the control board in the upper unit control box.)
a) The LED is on when the 12VDC is adequate and communications are
present.
b) The LED is flashing fast and steady when in the freeze mode. Evaporator has frozen and the freeze proctection switch is engaged.
c) The LED is flashing slow and steady when the delay on break timer is
activated.
d) The LED is flashing 1 cycle on and off for one second with high or low
12VDC. Check the incoming 12VDC power for OK.
e) The LED is flashing 2 cycles on and off for one second with a
communication problem. Problem with the control board in the unit and the remote.
Hope this helps.
Jeff
Rate me Please!!!
Jul 29, 2008 | Coleman Mach 15 Air Conditioner
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
NEC MultiSync MT1050 Multimedia Projector Logo
279 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
