AEG 88730 UPDATE
Has displayed error code C9 if left to end its activity. No drum rotation either wash or spin. Have removed motor and brushes which seem long and springs OK. Fills and pumps out OK. Have cleared the error code but still no joy. ANY IDEAS?
  • Anonymous Mar 22, 2014
    washing machine aeg 76560 update
  • 30 Answers
For a solution to your dilemma, I recommend that you first replace the brushes, then to reset the error code C9 hold down the pre-wash & short wash together and turn the control knob from off to gentle spin. this sequence should clear the C9 from your washer.
Posted on Aug 21, 2008
    New Friend:
Hello may hitachi washing machine can,t works it got c9 error tell me the easy soloution.
Posted on May 15, 2016
SOURCE:
How to reset aeg 88840 update ? Have c9 error, don't know reset combination, please help!
Error code C9 means tachometer impulses are missing so you could check carbon brushes (mostly), motor drive, tachogenerator, wiring.
Dado
Feb 22, 2015 | AEG Washing Machines
The machine flashes C9
On washing machine displaying error code "C9" on its' display. Normally this indicates that there is a mechanical or electrical problem with the motor (often the brushes need to be replaced).
It could also be an over-sized load of clothes in the machine, try to reset the before beginning to replace parts.
The solution is to put the dial in the off position, then turn the dial to the spin position while holding down the soak and pre-wash buttons simultaneously.
The procedure above is also necessary to reset the washing machine after replacing any parts once the error condition has occurred.
Feb 19, 2011 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 72 620 What does error code C9?
c9 means the electronics is not detecting any drum movement. check the carbon brushes in the motor this is usual culprit.
Aug 29, 2010 | AEG Lavamat 72640 Front Load Washer
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
I need a motherboard for a aeg lavamat l62622
I have an AEG WITH ERROR CODE C9 IT WONT SPIN OR WASH ,COUNTS DOWN THE CYCLE ,FILLS BUT CLOTHES ARE LEFT A STICKY MESS ,MOTOR AND BUSHES ARE FINE ,I HAVE RESET NUMEROUS TIMES BUT STILL GOES TO C9 ANY IDEAS
Feb 26, 2010 | AEG Washing Machines
AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Jul 04, 2009 | AEG Washing Machines
Aeg oko lawamat
c9 means the motor is not turning the drum. check carbon brushes in the motor.
Oct 29, 2008 | AEG Lavamat 88840 Front Load Washer
AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Feb 25, 2008 | Washing Machines
Washing Machines Logo
1,374 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
