You may try to change the compatibility setting for the program to Windows 95/98. Right clight on the .exe file and choose 'Properties'. Select the 'Compatibility' tab and choose the appropriate options.
Available OptiPlex GX520 Drivers: http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=PLX_GX520
You are right - the camera is not supported by logitech for Windows 7 and I am surprised that you have some level of use with it. A couple of things you can try - 1) Instead of restarting your computer just unplug the webcam for a few seconds and then plug it back in. (This will re-boot the webcam software) the same as restarting the computer) 2) Do a quick check running the webcam in Compatibility Mode Right click on the webcam icon on your desktop or the webcam file from 'All Programs' - select 'Properties' Select the 'Compatibility' tab Select 'Compatibility Mode' Use the dropbox to show the OS you have successfully used before Click OK Restart your computer
yes , it is compatible. Some peripherals may need an additional driver from the manufacturer website. Sabrent in this case. Here is the list of the latest drivers from Sabrent: <br /><br />http://sabrent.com/drivers.php<br /><br />Hope this helps:)<br /><br />
ok office 2003 is compatable with 7 so we are ok there, but your not telling me is did you upgrade from xp 32/64 bit and is this windows 32/64 bit. are you just trying to install the default folder to a differant location?
try copying the contents of the cd to your drive and install that way. do a system file checker also to make sure no corrupt or missing windows 7 files are causing the issue.
