Smudges on printout
Goodday Jay,
Thanks for the helpful solution on sc326 problem. I've solve the problem but another problem comes out. Every time i try to make copy it turns out smudges on the printout copies. I've done the developer initialization and set everything as the same with my other 1045 machine, but come to no avail. Really appreciate if you could help me on this.
Regards.
  • 92 Answers
Drum or fusing assembly most likly
Posted on Aug 29, 2009
  • chicagojoeco Aug 29, 2009
    drum or fusing assembly most likly
Recently bought a kodak 3250, and had to renew the ink cartridges. i did this twice and still cannot get printer to print any documents. as far as printing pictures is concerned the printout seems to come...
itcould be the coagulation of ink in between the cartridge better dip it in mildhot water for some times and replace it wiping the water . it would do thetrick and solve your problem . it has been practically tested.
If this solution helpful/useful for you please rate my solution. THANKS FORUSING FIXYA
May 16, 2011 | Office Equipment & Supplies
When i print it is having a smudges lines in the letter black only .how 2 solve it?
Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 08, 2010 | Office Equipment & Supplies
Sir my Ricoh 1045 machine have SC 326 problem, after taking a single copy the error code comes. please give a good solution to clear my problem. thanks
sc326 is a laser synchronization error. The problem is usually caused by the laser sync detection board or the LD unit.
Jun 02, 2010 | Ricoh Aficio 1035 Copier
My printer is smudging the left hand side of the printout. How do I clean it?
Check and verify smudging not caused by toner cartridge by removing toner from printer and checking the blue roller. DO NOT TOUCH the roller as oil from fingers may cause image defects. If toner good suspect fuser causing smudging on your printouts. Note fuser not considered a customer replaceable part for this model.
Mar 11, 2010 | HP LaserJet 1320 Printer
I have black smudges on my printouts. I using
This may be the cartridge itself, take the black ink cartridge out and check the head on it (the part that points in to the printer, usually down) and see if it is dirty or has ink smudges on it.
Mar 12, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Smudged printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Need to know what would cause smudges on a laser printer printout and what the solution would be?
its very common when the climate is humid.the drum and the toner powder of ur laser cartridge catches moisture which then produce smudged printouts.to solve this problem u need to blow the hot air dryer on the drum and powder unit.the moisture will go off and ur prints will be fine thanks.
Sep 16, 2008 | Office Equipment & Supplies
Error SC326 on aficio 1045
Hi there below is what is states in the service manual.
326 C 2nd laser synchronization error
The 2nd laser synchronization signal
cannot be detected by the main scan
synchronization detector board even if
the laser diodes are activated.
• Poor connection between the laser
synchronization detector board and
the LD unit.
• Laser synchronization detector board
out of position
defective
• LD unit defective
Hope this helps you.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
Smudging and overlapping
By smudging do you mean the print is actually rubbing off?
I am going to assume you are seeing some reprint on all printed pages.
If I am understanding correctly, what you have is a bad fuser, most likely a bad heat roller.
That is the heated area just before the pages exit the machine.
The coating on those rolls wear out with time, or may even debond from the aluminum. The ink does not then properly melt into the paper, sticks to the roller and progressively becomes worse.
Replacement of the fuser should resolve that issue. That's simply a normal wear item.
Mar 14, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
67 people viewed this question
k24674
jasbo
jasbo
