Question about Hitachi Televison & Video
Will not load tape
Hitachi VT-MX910EUk. Will take in tape cartridge but does not pull out the tape to the head - simply ejects every time. Assume some form of tape registration is failing? If I crank the main loading gear by hand I can get it to take the tape to the head - but never under it's own power. Regrads, Neil
  • yellowwestie Aug 20, 2008
    Shuttle83.
    Many thanks for the advice, sounds like my issue.
    I've noticed a perspex-like post on the main-board, almost as if it's a fibre optic(?) that pokes up into the hole in the base of each video cassette - almost between the spools? There's no visible light that I can make out from the thing.
    Will investigate and if easily available will see if I can replace.
    Regards,
    Neil
  • 979 Answers
I concur with shuttle 83's analysis; that the sensor(s) in the carriage have gone south on you. These are simply photo transistors, and are readily available at just about any parts supply house...accordianman
Posted on Aug 19, 2008
    Genius:
  • 1,139 Answers
Hello yellowwestie,
You may have a bad tape position sensor assembly (LED and photo transistor). It's purpose is to detect where the tape is in the loading process, and if the tape is not in the proper place at the proper time the tape is returned to the cassette and the cassette is ejected. This sounds like what you are talking about. I would suggest getting a schematic and checking the bias voltages (with a multimeter) on the tape position sensor assembly. If the sensor is bad replace it, if it is not check the tape sensor assembly circuitry.
I hope this helps
Thank you,
Shuttle83
SOURCE:
Eject the tape on Hitachi VT-FX695. It stays on for about 45 seconds and will not eject and then powers off.
hi,
the door mechanism is may be gripped because of a small kick...
did you try to open the door with a full charged battery and with the wall plug connected too ? help it with a toothpick or the corner of a credit card...
if this doesn't work, it may be the motor that is dead, do you ear any little noise when asking the ejection ? if yes, it is the mechanic, if not, it is the motor or the motor driver that is dead.
cheers,
mich
Nov 06, 2014 | Hitachi DZ-MV550 DVD Camcorder
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
VCR immediately ejects tape or draws it in and starts to eat it.
All pinch rollers and heads need to be cleaned! They probably got sticky from not being used.
Jan 17, 2014 | RCA Hitachi Vt-fx665a 4-head Hi-fi Vcr...
I put a vhs tape in an the vcr turns off by it self a green light keeps flashing by where it says cst in. I have a Hitachi DVD/VCR COMBO DV-PF2U. I also can not get the tape out
Unplug the power supply for thirty seconds and plug back in, this will reset the processor and might eject the tape. If this fails the next step is remove the top of the combo unit this will give access to the vcr tape, if the tape is spewed in the machine and wrapped around the video head and other mechanical parts use scissors to cut the tape and carefully removing the particles, press power to eject the tape for normal operation. However! if the vcr tape is okay, there may be a loading problem, broken drive belt, bad idler assembly to name a few, this is where a technician will be needed but may not justify cost.
Jan 23, 2011 | Hitachi DV-PF2U DVD Player/VCR
Insert backup tape, can hear it, then ejects, it doesn't matter which tape (two week cycle) - none will stay in drive. HP Ultrium 215 LTO 1
Sounds like a lost leader. When the tape is loaded there is a leader in the tape drive that hooks onto the end of the tape and pulls it out and onto the take up reel. If the leader gets out of position then the drive fails to load the tape and it is ejected. To fix it requires taking the drive apart. This might be a good time to upgrade to a newer model LTO. They were redesigned to eliminate this problem.
Jan 10, 2011 | HP StorageWorks Ultrium 215 LTO 1 Tape...
Well ont eject all the way out
There is a problem with the loading basket, or the VHS tape is stuck inside and the eject mechanism can not cycle the tape out. To check this, open the lid so you can see the tape, if it is wrapped around the head and roller, hit the eject button to see if the tape is being pulled or jammed, cut the tape with scissors to free it up to see if it will pop out. If the tape is okay, it means you have a faulty loading basket.
Dec 30, 2010 | Samsung VR3607 VHS VCR
How many motors are in the VCR section? example 1 motor for play, 1 motor for hi-speed rewind, 1 motor for hi-speed forward.
There are only 2 motors on the VCR sections.1 motor for the rewind backward and speed foward.1 motor for take in the VHS tape and eject the tape.The play button also used the same rewind backward and speed forward motor to push the film foward to the VCR play head head drums to play the tape.
Nov 24, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
HITACHI vcr DOES NOT LOAD TAPE
It's more than likely a slipping belt in the tape mechanism
If you are technically inclined it can be fixed for around $3.00
If you are not then it would be advisable to buy a new VCR because the repair cost would be more than the cost of a new one .
Mar 27, 2009 | Hitachi Televison & Video
Sony Cam DCR-PC100, "eats" tapes and when ejecting, pulls tape
The take up spool is not working upon ejecting. I would take it to a Sony Service Centre for service.
Jun 03, 2017 | Sony Handycam CCD-TRV43 Camcorder
Vcr will not load vcr cartridge
The tape mechanism is not loading and/or driving the VCR tape properly. Most people don't realize that the tape is physically pulled out of the VCR cassette and wrapped around the video heads in a semi-circle configuration. Your VCR guides are pulling the tape out but not retracting it into the cassette shell when you press eject. Causes: mode switch, mechanical failure, video head speed/drive problems. All these problems are somewhat complex for a novice repair person and don't forget that new VCR's are selling for $30 at the big box stores....Glen.
Jun 05, 2008 | JVC DR-MV1S DVD Recorder/VCR
Televison & Video Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
