Question about Garmin Nuvi 760 Handheld GPS Receiver
360 Sound lost
Hi, My Nuvi 360, 15 days after purcahse as loss the sound. of course volume is set to highest and not on mute...; suggestion?
  • Garmin Master
  • 2,130 Answers
Try listening with headphones. If you have sound there, then your internal speaker has gone bad.
- Jim
Posted on Sep 03, 2008
Nuvi 2555mt lost voice
First, do you hear beeps when you press a selection on the screen? If yes, then your speaker is OK and the audio circuits are OK in the unit. Make sure that you have a voice selected in the voice menu. Some units have an audio mixer screen and provide different volume settings for navigation (voice) and system (beeps). maybe the volume for the voice (navigation) is set to off. If you don't hear any beeps when you touch the screen AND you don't hear a voice, make sure that the sound isn't set to be muted. If the sound isn't muted, you may have a defective speaker. More information on audio issues can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Apr 18, 2014 | Garmin nuvi 260W GPS Receiver
Tip
No Sound or Garbled Sound on a Nuvi Series GPS
I've seen many posts of "No Sound" or "Garbled Sound" for the Garmin Nuvi Series. This is a common problem with the Nuvi.
In order to troubleshoot this problem, we need to determine if it's a hardware or software issue or a setting issue.
No Sound:
1. Try the obvious. Is your volume setting turned up?
2. Is the sound muted with the mute button?
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
Garbled Sound:
1. Does the sound seem to be better at lower volume settings?
If you still can't hear audio or if the sound is garbled, then we now have to determine if the internal speaker is defective. The easiest way to do this is:
1. Plug a set of headphones into the headphone jack. Now try listening to the sound. Listen for the touchscreen beeps, MP3 audio, voice directions, etc. Try adjusting the volume using the headphones. If you can hear sound through the headphones and it's clear and not garbled, then your internal speaker is defective.
The headphone jack is not only a jack but it's also a switch. When you plug in your headphones, the audio amplifier of your Nuvi is switched from the internal speaker to the headphone jack. When you unplug the headphones, your Nuvi's audio amplifier is reconnected to the internal speaker.
Now, if you can't hear audio through either the internal speaker or the headphone jack, you may have a different problem.
1. The internal audio amplifier (hardware) is defective.
2. There is a software problem. You could try resetting your Nuvi with the reset button or perform a factory reset. The software problem is more likely if you can hear MP3 audio or touch screen beeps but not speech.
The internal speaker has a voice coil. The voice coil is nothing more than a thin piece of long wire, wrapped around a magnet, numerous times. If you can't hear any sound, it is very likely that this coil is "open"; meaning that the wire has broken inside. If the sound is garbled, this is an indication that the speaker is mechanically defective and not reproducing the sound as it should. The speaker has a "diaphram" that moves in and out as it reproduces sound. If the diaphram has been damaged, it can't move in or out like it should and reproduce the sound clearly. There is also a possiblity that the voice coil has shorted windings, meaning that instead of it being a long piece of wire, it's now shorted to its adjacent windings and is electrically shorter now. Again, this can impact the reproduction of sound.
So, why did your speaker go bad?
1. It's possible it was defect in the manufacturing process and failed prematurely.
2. You might have had the volume up too high. I recommend using the lowest volume level possible. High volume levels put greater stress on the diaphram and may overheat the voice coil.
3. A speaker is an electro-mechanical device. It's subject to being damaged if you happen to drop or jar your Nuvi and/or operate it outside of its normal operating parameters.
What's the Next Step?
If your Nuvi is under warranty, I strongly suggest that you contact the manufacturer and tell them what happened. Tell them all of the steps you have gone through to confirm that the speaker is defective. If the warranty is still in effect, they should repair or replace your Nuvi.
If your Nuvi is out of warranty, try calling the manufacturer anyway. You have nothing to lose. Maybe they will replace it anyway.
If you have no sucess with the manufacturer, you will need to take your Nuvi to someone who is qualified in repairing your Nuvi.
I hope this tip has been helpful to you. Feel free to contact me if you have further questions or require further assistance with this problem.
Best wishes,
- Jim
http://www.sharcnet-usa.com
on Oct 01, 2008 | Garmin Nuvi 350 Car GPS Receiver
Tip
No Sound or Garbled Sound on a Garmin Nuvi GPS
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 610- working perfectly then sudden crackling and now loss of sound/or at best crackly and intermiitent sound- but map/navigation and on-screen directions fine
Check the audio output setting on the nuvi. There is a possibility that the FM Transmitter setting has been turned on or that the device has been muted.
To check the audio output setting:
  1. Touch the Speaker icon below the Wrench icon.
  2. At the bottom of the screen, touch Audio Output.
  3. Make sure that the Internal Speaker is selected and touch OK (660, 670, 680, and 5000 models only).
  4. Make sure that the MUTE box does not have a check mark in it. If it does, touch the box to clear the selection.
  5. Make sure the volume level is at a reasonable percent level.
Sep 24, 2010 | Garmin Nuvi 610 GPS Receiver
Garmin Nuvi won't talk. No sound when programming
If the mute is not checked, try plugging in a set of headphones. if you now hear sound, your internal speaker is blown. Please see this link:
http://www.sharc.net/gps_audio_repair.htm
- Jim
Apr 27, 2010 | Garmin nuvi 750 GPS Receiver
Tip
No Sound Issue on the Garmin Nuvi Series
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin nuvi 350 GPS Receiver
Voice stopped
Please see this link for more info on this problem:
- Jim
Feb 14, 2010 | Garmin NUVI 360 GPS Receiver
Garmins Nuvi 350 - voice interactive lost
I have the same problem with my Nuvi 350. It's only about 2 months old and the sound went. I turned it on the other day to use it and the sound did not sound right, it sounded like the speaker was blown. I turned it off and turned it back on and that was it, the sound was gone. I did everything possible and can't get the sound to come back. I called Garmin and now I have to send it in for repair. I looked around the web and noticed that Garmins have big issues with the sound going on the units. I hope they fix that issue.
Jul 28, 2008 | Garmin nuvi 350 GPS Receiver
Directional voice not operable
did you unintentionally turn the volume down or mute the volume?
Jun 15, 2008 | Garmin nuvi 200W GPS Receiver
Installed new monitor, lost my sound
If your previous monitor had built in speakers and your new monitor does not you are going to have to purchase new speakers. If your new lcd monitor has an audio input you can purcahse a sterio mini jack cable for under $10 at any store that sells computer stuff (circuit city, best buy, walmart, target, etc). Simply plug one end into your monitor and the other end into your computers audio output jack (usually color coded green). Now of course if that monitor does not have built in speakers your only option is to purcahse a set of speakers for the computer. These usually start at around $15.
Aug 10, 2007 | LG Flatron MW-30LZ10 30" LCD Monitor
Garmin Nuvi 760 Handheld GPS Receiver Logo
91 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
