Question about RCA RT2600 System
Rca rt2600 when i press power botton i hear a click sound and doesn't turn on
    Problem Solver:
  • 13 Answers
You're having a startup problem, u should take to an expert.
Posted on Aug 29, 2008
RCA RT2600 sound problems
You should first try unplugging it for 30 minutes and that should reset it and has fixed the problem on other ones before.
Also, do the speakers hum at all or is it dead silence?
Thank you for further comments to my question.
Have a Good Day.
Apr 20, 2008 | RCA RT2600 System
My RCA T19060GY TV/VCR will not stay on. When I push the power button on the unit itself (I don't have the remote.), the green indicator light comes on for two seconds and I hear to click sounds
the clicking sound is due to the relay is getting turn on but doesn't stay because of bad component in the power supply board or in the main board. you must check first the bridge type diode and FET transistor using an analog or digital tester.
Aug 16, 2012 | RCA Televison & Video
I am getting no sound from my speakers, but im getting video. i have all the outputs and inputs in the right places. what are some possible problems?
Operator error. Mis-set switch somewhere Use a medium or low volume level until you find it.
Have you followed the manual used the Test Tones to set it up? How did it sound at that time?
Have you and evaluated every indicator on the front to understand what they mean in the context of source selection?
Register and download the manual for free at
See page 23.
No audio.
Make sure the speakers are connected.
Check the input connections.
Check the power cord connections.
Make sure the MUTE signal on the front panel is off.
Make sure the digital setting (optical, coaxial or analog) is correct.
Check that the headphone is not inserted.
Mar 07, 2011 | RCA RT2600 System
Rca rt2600 no sound, if you switch on the power the display comes up and within a seconds it shows OVERLOAD in the display and it automatically turn off. all speakers had disconnected too. please help me...
One of the audio output amplifier ics are toast the faulty one will need to be desoldered from the board and replaced, they run at about $10 each normaly. The faulty one will generaly be quite burnt.
Aug 18, 2009 | RCA RT2600 System
I have a new Phillips 42" LCD and it only has a digital audio OUT on it, how do i hook it up to the RCA RT2600 with the digital audio...for some reason it is not wanting to give me any sound?!?!?!?!?
Be sure you have selected digital audio and enabled the digital audio out on the phillips tv audio setup menu, then be sure that the RCA rt2600 input mode is set correct
Mar 19, 2009 | RCA RT2600 System
RCA RT2600 Speakers stopped working.
I bout mine used an it has absolutely no problems you probably got one that they knew wasnt really working in the first place.
Jan 25, 2008 | RCA RT2600 System
Your receiver has blown out you need to buy a NEW Receiver and sub-woofer (the sub isnt compatable with better receivers)
Jan 06, 2008 | RCA RT2600 System
Rca tv mm36100
There is a common problem in this unit with R14103 (33k 2watt ) resistor that opens. When open SMPS will not load so no other voltages beyond the 5v source to click the relay.
Another possibility is the Horz. drive transformer, RCA p/n# 243859 board location T14451.
Either of these possibilities are inexpensive fixes reletively speaking, so I would advise having it estimated by a qualified shop for repair..
Nov 24, 2007 | RCA MM36100 36" TV
DVD problems
u having a problem with your tv . take it to a professional.
Nov 06, 2007 | RCA RT2600 System
RCA RT2600 System Logo
323 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
