Have a lg washing machine and its noisy when spinning
  • deray451 Sep 01, 2008
    Whirlpool washer LSR5223. Tub bangs against side of machine when on spin cycle. Cloths are loaded evenly. Tub seams loose when moved by hand and is tilted towards front of machine. Any ideas?
    Genius:
  • 1,198 Answers
We need more input. Top or front loader, how old , brand and model would be nice. Is the sound steady or out of balance thumping? Tell us all.
Posted on Aug 18, 2008
Noisy during spin cycle
Yes that is definitely bearing noise you here.
Jun 21, 2017 | LG Washing Machines
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
My LG Washing machine is not spinning. It also comes up with OE. Can you help
Check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
The most common problem with spinning on this model machine is the tub bearing. Normally it would be very noisy when it did spin.
Massive job to replace it.
Dec 06, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
Front load washer no longer spins
Big problem with front load washers the tub bearing more than likely seized replace the machine the parts and labor close to 1000 I fix these all day long under warranty.
Apr 02, 2014 | LG Washing Machines
Washing machine
buy a new washer,the spider gear is gone probably from to much detergent,it's around 500 bucks for the part
Feb 11, 2010 | LG WM-2277HW Front Load Washer
Very noisy on spin cycle only
Hi, please describe the type of noise you are hearing. If it is a grinding type noise, it is likely to be the drum bearing.
Oct 25, 2009 | LG WM1814CW Front Load Washer
Noisy on spin cycle LG WM1832CW
this is joyce
Go to lg.com and download your manuel put in your model #
thanks
joyce
Feb 07, 2009 | LG WM-1832C Front Load Washer
LG direct drive washing machine is getting increasingly noisy when at the spin stage
generally when a machine gets noisy in spin cycle it is due to bearings being worn open the door with the machine empty and try lifting the the drum upwards if it moves then it will be the bearings
Jul 12, 2008 | Washing Machines
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
