Question about Cameras
How to work with flash
When do i move the flash to the right side and when to the left side?
  • Igor katzman
    Igor katzman Aug 18, 2008
    I have nikon sb 80
    Problem Solver:
  • 39 Answers
  • yakov75 yakov75
    yakov75 yakov75 Aug 18, 2008
    it's depends what you want to take pictures of...
Only one side fired
Is there a small switch on the unit with which you can select left side flash, right side flash or both sides together ? If so, this may have been inadvertently moved, causing the situation you describe.
Feb 15, 2016 | Nissin MF18 Macro Ring Flash Nikon Black...
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    I need to reset the time
    Not sure if all Casios are the same but mine works like this.
    Push bottom left button 3 times until Seconds digits flash. Adjust Seconds by pushing or holding in bottom right button. Push in top left button to move to Hours ( will flash } Adjust as for Seconds.
    Push in top left button to move to Minutes, adjust then move on to Date, etc.
    Push bottom left button at any time to return to normal. Good luck!
    Apr 02, 2011 | Casio Watches
    FIAT DUCATO 2005 WHERE IS THE FLASHER RELAY UNIT INDICATOR ON LEFT SIDE DON'T WORK, HAZZARDS ON LEFT SIDE DON'T WORK, ITS NOT THE BULBS AS ALARM FLASHES ALL 4 INDICATORS.
    2006 fiat ducato left indicator only flashes a couple of times then stops also the hazard lamps only work on right side
    Sep 28, 2010 | 2006 Fiat Strada
    I bought an old timex indiglo watch it has a button on the right middle and left bottom, how do i adjust the date?
    Thank you for contacting FixYa.
  • Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
  • Best regards. Jewel
    Sep 08, 2010 | Timex Watches
    Lights flashing
    If your chair is in freewheel (levers on back of motors not in drive) then the light will flash. But are the lights scrolling left to right or right to left? You can check for freewheeling by trying to push the chair from behind if it moves easily then it is in freewheel and you will have to move the levers to the drive position. You need to give more info of the flashing lights are all the lights flashing are only some flashing? etc
    Aug 16, 2010 | Invacare Supply Group Invacare Pronto M91...
    Very slow printing when it does run. has a flashing orange light alot too. have to unplug and replug to work
    One or both print cartridges is failed.Turn the printer on and open the cover.the carriage unit will move and stop in the left side of of the printer.There is a yellow arrow on the carriage unit.There is a two marks in the left side of printer.If the arrow show left mark replace color cartridge.If show right mark replace black cartridge.
    Dec 01, 2009 | HP DeskJet 940c InkJet Printer
    Turn Signal problem
    2003 mini cooper . Went for a clean up,and came back with the righ turn signal on all the time. every thing else works fine when you turn left or 4 way flashers. Any help will be appriciated. Thanks in advance
    Jul 30, 2008 | 2002 Mini Cooper
    Cameras Logo
    217 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
