Question about Acer Aspire 5002WLMi Notebook
Aspire 5002 WLMi getting turnoff
When performing virus scan laptop gets turnoff .Due to this reason i tried to format it but when os cd starts run laptop is getting turnoff same time fan producing more noise .
  • lmiller_wcna Sep 09, 2008
    same thing - I turn on my computer and after 2-4 min. it just shuts off.
    Support told me to do a restore, which I cannot get through, because it keeps shutting off !!! Computer was only used maybe 10 times before having this problem. Please help
It is because it overheats... try new bios or download overclocking software and do the opposite of overclocking (making it run slower)
Posted on Oct 24, 2008
  • 56 Answers
There is a CD tool called "Ultimate Boot CD" which can be downloaded athttp://www.ultimatebootcd.com. On this CD there are quite a few toolsthat you can use to test your RAM, CPU, Hard Drive, etc.. for problems.Just boot up with this CD and select the corresponding testing programto use. Test each component until you find the component causing the issue.
Cause it seems something is overheating.. Probably the CPU.
Posted on Aug 18, 2008
Laptop dell inspiron n5010 hanging suddenly
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. Here is a few good virus scanners that you can run to check your PC:
http://c74b6qq6lbo8zlievtv2q810g1.hop.clickbank.net/?tid=DMWDH6W3
Nov 24, 2011 | Dell Computers & Internet
Need windows xp 64 bit drivers for acer aspire 5002 N WLMi. it's not privided with the cd
http://support.acer.com/us/en/product_support.aspx?tab=1 Click on the link above and select your notebook from the product list and the drivers will be available for download.
Dec 28, 2010 | Acer Aspire 5002WLMi Notebook
My Acer Aspire One will start up ok but once it starts to open windows the scrolling bar on the bottom just starts to move slower and slower and then it never opens. What can I do to fix this?
too many programs running in the background?
uninstall ms search tool, this has major impact on system performance
also try to upgrade the RAM
Oct 16, 2010 | Acer Aspire One PC Notebook
My 5002 WlMi won't boot. All that happens when
Replacing a motherboard on a notebook is generally only recommended for professional technicians. As a last resort before trashing it, it might be doable for a resonably skilled person, but finding/buying the right motherboard is another matter.
Though, it might not be the case that it's the motherboard that's faulty.
If you can post a more detailed description of the problem, when it occurs, and if there are any life-signs at all (HDD-lights, screen, fans et.c.) it might help getting some answers.
Apr 11, 2010 | Acer Aspire 5002WLMi Notebook
My laptop has a virus and i cant afford a virus disc
Most of the virus programs run on stealth mode and run along with some application injecting its threads into the Application threads stacked in process queue. If the antivirus program fails to remove or quarantine, this could be either due to non detection of virus code, or due to inefficient coding in the virus program to seize the operation of the Virus program and seize its operations.
In such a case it would be wise to create a onetime bootup disk with Anti-Virus program. Before the OS starts, Always perform an antivirus scan and reboot a clean OS. Reason being that when Windows OS loads the Kernal takes control of all Key operations and we wouldnot have the right privilege or access to remove the virus program. So we boot from a boot disk and run this antivirus program to remove any infected file or code from the system to have a clean OS.
Feb 13, 2010 | Acer Aspire One A150-1006 Notebook
Hi, I have an acer aspire 6920g and I recently had to format my harddrive due to major viruses on my computer, I have installed all the drivers I can get for this machine but i cant seem to get the full...
dont use lot of add ons. and i guess u pc till have virus. use kespersky latest vertion. formet ur OS. install then install anitivirus, then all drivers updated the anti virus then scan all drives please. i am 100 % sure some other driver infected by virus. plz follow these.
Jan 22, 2010 | Acer Aspire 6920 Notebook PC
My lap top get hanged after loading windows, when i start it.i have refresh my windows for more then 4 times, even i format my hard disk as well
hello
The problem you have explained here is not the OS problem.
Please don't format your system anymore.
The following may be your problem....
  • when the windows is loaded the system hangs due to interference among various application software like messengers, anti virus etc.
so you should disable the option which execute them at the starting of the system.
so open each software which automatically starts at the starting of the windows and disable the option of automatic starting after boot.
  • The other problem may be your firewall.Disable the firewall and check if system is working fine. if yes the look for the program which the firewall is stopping and disable it.
  • The last reason can be your anti virus which is stopping the execution of certain program. Update the anti virus and scan fully.
i know that you have mentioned that your system completely hangs..so how you will do all this..right?
For that leave the system idle and keep trying the refresh button.
or
you can do this with safe mode.
or
Do end task operation.
hope this will solve your problem.
Thank you
Aug 13, 2009 | Acer Aspire 1640Z Notebook
Still SLOW after a complete recovery (with disk) the computer
hello!!! your computer slow maybe some files is missing due to slow performance
or when you virus scan last time some of your files in the drive c are infected by the virus
and the anti virus normally he do to delete automatically whose files unable to repair by
anti virus scaner your best to do to reformat using os/operating system cd, or try upgrade your memory ram...
thank you!! hope i can help you..have a good day!!!
Jul 06, 2009 | Sony VAIO VGN-FS550 Notebook
Windows explorer
This could be due to a spyware/virus. Have you tried running a virus scan? As you can still get online try an online virus scan: http://www.pandasecurity.com/homeusers/solutions/activescan/ click SCAN PC NOW
Sep 02, 2007 | Acer Aspire E380 ASE380-UD500A PC Desktop
Acer Aspire 5002WLMi Notebook Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
