Posted on Aug 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My HPDeskjet F300 Series has not been printing.Window Status was showing Door open.This morning when I switched on the printer it started churning out prints until I cancelled. Now it will not print and window status shown Offline. I Have done a self test printout and all look OK.Please advise. I have also pulled out the power cord and replaced it.Printer lights look OK
  • 2 more comments
  • Anonymous Oct 10, 2008
    I have the same problem. The printer shows as offline. It wasn't printing before but it printed after following your instructions. HOWEVER, under printer it still shows OFFLINE. Please help
  • dosanjh36 Oct 10, 2008
    I have had the same problem. The printer showed Offline status and was not printing. I followed your steps and it has started printing but it still shows OFFLINE status. Please help.
    By the way, I have Windows VIsta installed on my laptop and there were no drivers in the CD that you gave me. I had gone on your website and had downloaded the driver, but I can't see that program which used to be on my desktop (Windows XP) through which I could do scan and other kinds of things.
  • Anonymous Apr 02, 2009
    my HP Deskjet f300 is set to off line **** i dint put it there please what do i do to fix this?
  • aslamkhansr Sep 19, 2009
    I can copy , scan but can not print as window shows offline, what do I do to get it printing?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2568
Points
62
Go to Contol Panel, and in Classic View select Administrative Tools, Services, Print Spooler. Now, stop and start Spooler.
  • lmcgivney1 Apr 26, 2011
    After trying everything to print my daughters exam pieces this worked! Thank you so much for posting,
    from a tired grateful mum! :)
Anonymous
Level 3:
Prodigy:
An expert who has answered 500 questions.
Sergeant:
  • Master 564 Answers
  • Posted on Aug 18, 2008
Anonymous
Master
Level 3:
Prodigy:
Sergeant:
Answers
564
Questions
0
Helped
114797
Points
1002
Sounds like blown drivers
take out old set, go to www.hp.com get fresh set of drivers
install
try it again
http://tinyurl.com/6qcpgy
HP Deskjet F300
When you click 'print' on your computer, change the printer-settings to "double-sided" or "print on both sides", and then click OK. The printer will do the rest.
tip
Samsung SCX-4500W restore wireless printing on cryptic error
For those having trouble wirelessly printing to their Samsung SCX-4500W printer from a Windows computer, I have this "easy" 13-step process that usually fixes my most common printing problem:
The symptom:
You haven't used your printer in a couple of days and have just hit the print button in an application you wish to print a document from. Instead of your printed document gracefully emerging from your printer, a Samsung status window appears on your computer above the task tray, cryptically announcing "The current printer port is not supported for the current printer status". You scratch your head in complete confusion.
The solution:
  1. Go into the room where your printer is. Observe that it has dropped its wifi connection and not reconnected automatically - the blue light indicating wifi is no longer illuminated.
  2. Turn off the printer, wait a few seconds, and turn it back on.
  3. Rebooting always causes a blank page to be ejected - how annoying! Open up the tray and reinsert the blank sheet.
  4. Wait for the blue wifi light to come on.
  5. Return to your computer and open the printer job queue window. Locate your document in this window with "Error" status next to it: right-click on it and select restart so its status changes to "Printing".
  6. After a while, notice the status has changed to "Error - Printing" or "Error - Sent to printer". Since restarting the job was not successful, right-click and select cancel. Press the OK button in the confirmation dialog. You may have to do this a second time before the job clears.
  7. Return to the application you printed from and re-print the document.
  8. Double-click on the blue Samsung "S" icon in the task tray. A window titled Samsung SX-4500W Series will appear in the lower right. Observe the status first says "Please wait..." then show the same cryptic message "The current printer port is not supported for the printer status". Grrrr.
  9. Check if your computer really can access the printer by opening web browser and typing its ip address. For me, it is 192.168.1.70. Alternatively, click the "Printer Setting" button in the window of step 8. Observe that the printer reports it is alive and ready for action. This is good.
  10. Check if any other Samsung software is able to use the printer: Open SmarThru 4 software, select "Scan To", "Folder", then hit "Scan" button. Observe that scanning from the printer works absolutely fine. Close SmarThru. So the problem is just the crappy printer driver.
  11. Close any Samsung windows you have open. Navigate the start menu to Samsung SCX-4500W Series->Maintenance. The installer will run in maintenance mode and find your printer on the network (and show its ip address), as well as an option to use it on "Local Port". Select the printer on network and click Next. Select "Samsung SCX-4500W Series printer driver" to repair and hit Next. The driver will re-install. Click Finish when done.
  12. Return to your application you wish to print from and activate the printing of the document again.
  13. The Samsung status window will once again appear in the lower right proclaiming "The current printer port is not supported for the printer status". Ignore this stupid message and close the window. Go to the room with your printer and with any luck, you will find your printed document waiting for you!
Once you are well practiced at this, and can fully appreciate how useless Samsung's software developers are, you can just do steps 1,2,3,4, 5, 6,11,12, and 13.
Connection problem with my pc and printer. F300 series
Disconnect and reconnect the USB Cable. and then try this:
Solution 1 On the Computer:
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
MorrigI have a corrupted cd for my windows vista the cd is hpdeskjet f300 all in one series version 8.0.1 bar code Q8100-10019 can i buy a replacement
Click here Click on above link select your model then os then download driver and install. Let me know if you need further assistance. Thanks for using FixYa.
Won't print , status que sys it is.
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
I have an hpdeskjet 960c. Will not print
follow the steps provided below..
  1. Open Ms word
  2. click on file
  3. click on page setup
  4. click on land scape and close the window..
4helpful
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
I have an HP deskjet F300 All-in-one series, using it for a year, no problem. I am an elderly not very good operater though. I don't know what I might have accidentally changed. today I am trying to print...
offline means that you have it not in line ..open your start button(bottom left of screen) then settings, then control panel will appear...directly under that is a line that says Printers..click on that..it will open up another panel..find your printer.
right click on your printer, and select use online
k24674
ADMIN Andrew
ADMIN Andrew
