Question about HP Officejet 5610 All-In-One InkJet Printer
Unable to create MSXML instance with HP Psc 2210
For some reason and apparently I'm not the only one, recently this error message has occurred. Any remedies available. I have downloaded a number of MSXML files, no help there. I have uninstalled and reinstalled the software, no help there either.
Regards
DS
  • 234 Answers
Please try the steps mentioned in the link bellow, Make sure you do not mess-up anything:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00292756&cc=us&lc=en&dlc=en&product=441125
Good Luck
Posted on Sep 04, 2008
6ya staff
SOURCE:
My computer doesn't recognize that my printer is hooked up every since I unplugged it and moved it.. I don't have the manual and I know that there is a certain order in which things are pluged in.
To avoid errors, install the HP PSC software before you connect the HP PSC to your computer. If an error message appears and you clicked Next or OK, do the following:
1 Press Esc on your keyboard to exit.
2 Turn off your HP PSC.
3 Disconnect the HP PSC from your computer (detach the USB cable).
4 Follow the software installation steps outlined in the Setup Poster that came with your HP PSC.
If you receive a message that you have a previously installed version, you will not be able to finish installing the HP PSC software. You will have to uninstall the previously installed version in order to install the HP PSC software.
If your computer is unable to communicate with your HP PSC
If communication cannot be established between your computer and HP PSC (for example, the HP PSC status icon has the yellow error triangle), try the same tasks outlined under If Microsoft’s New Hardware Found message does not appear on page 57 of the manual.
Here is a link to the manual for your printer...
http://h10032.www1.hp.com/ctg/Manual/bpu05065.pdf
Jan 27, 2010 | HP PSC 2210 All-In-One InkJet Printer
Hp 2210 error message after cartridge replacement
hi
It seems that the cartridge which you are trying is not ment for this printer can help you but for that you have to visit----http://tinyurl.com/ng46w9
Jun 22, 2009 | HP PSC 1610 All-In-One InkJet Printer
HP 6110 check cartridge error won't clear with new cartridges. Anyone know how to fix this?
You could try this way first as its a lot quicker and easier than the official steps from HP:
Just hold down the ENTER button and then press the MENU button. There will be a series of 3 fast, high beeps. Then everything resists and is a-okay. Both problems go away.
OR The HP way as listed below:
The ink cartridge-related error messages may occur due to one
of the following reasons:
* The ink cartridge does not make a proper electrical contact
* The cartridge is bad or wrong
* The cartridge is remanufactured or refilled
To resolve the error, follow these steps:
Step one: Check the print cartridges and clean the cartridge contacts
Even if the cartridge is new, follow these steps to clean the print
cartridge contacts. Print cartridges have a substance on the contacts
to keep them from corroding during storage that may cause poor
electrical contact between the print carriage and the print cartridge.
1. Verify that the product is turned on.
NOTE: If the HP product is not turned on, you will not be able to
remove the print cartridges.
2. Open the top cover or the cartridge access door in one of the
following ways:
* Pull the control panel forward and then lift the top section
toward the back.
* Open the access door on the left or right of the unit. This door
may be located under the scanner glass lid on some flatbed
products.
* On many flatbed products, you raise the front center section of
the unit to access the print cartridges.
* Raise the cartridge access door on the front of the product.
3. After the print carriage stops moving, unplug the power cord. You
must unplug the power cord to prevent the print carriage from
moving.
4. Remove both print cartridges.
5. Verify that the part number on the cartridge is the correct part
number for the all-in-one and that the carriage is not blocked
preventing the cartridges from moving. Visit the following HP Web
site for a cartridge compatibility chart.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpa00586
6. The electrical contacts of the print cartridge are coated with a
thin layer of grease to protect them from oxidation. This grease
may inhibit the electrical connection and should be removed. Using
a cotton swab or cloth lightly moistened with distilled, filtered,
or bottled water, clean the electrical contacts of the cartridge.
This usually occurs with a new ink cartridge, but may also occur
with an older cartridge.
NOTE: When an all-in-one is used frequently for black and white
printing but infrequently for color printing (for example,
an all-in-one that is used primarily as a fax machine), the
color cartridge will still eventually fail and need to be
replaced. The pins in the print carriage can cause dents
on the contact points of the color cartridge over time
(usually between six and twelve months).
7. Wipe the contacts with a dry, cotton cloth.
8. Reinsert the cartridges and lock them in place.
9. Close the top cover or access door and plug in the power cord.
10. If the error persists, repeat these steps. If further cleaning
fails to resolve the error, proceed to "Step two: Clean the
print carriage contacts" section.
Step two: Clean the print carriage contacts
Have the following materials available to clean the print carriage
contacts:
* Cotton swabs or any soft material that will not come apart or leave
fibers (for example, a scrap piece of clean cotton cloth).
* Distilled, filtered, or bottled water (tap water may contain
contaminants that can damage the print cartridges).
CAUTION: Be careful not to get ink on hands or clothing.
To clean the cartridge contacts inside the product, follow these steps:
1. Turn on the unit.
2. Open the top cover or cartridge access door.
5. Using a cotton swab or cloth lightly moistened with distilled,
filtered, or bottled water, clean the electrical contacts of the
print carriage.
6. On models equipped with locking latches, lower the latches.
7. Wait five to ten minutes for the contacts to dry and then plug in
the power cord. The unit will begin to reinitialize. Wait until
the process is complete before proceeding.
8. Reinsert the print cartridges when prompted and then close the top
cover or access door.
9. If the message recurs, replace the print cartridge indicated by the
message.
* If you are using refilled or remanufactured cartridges or non-HP
cartridges, replace them with new HP cartridges. HP cannot
guarantee that refilled or non-HP cartridges will function
correctly in HP products.
10. If the problem still exists, replace both print cartridges. Since
the cartridges are electronically connected through the printed
circuit board, the cartridge not indicated in the message might be
the causing the failure.
If the issue still persists, please click on the link below and install
the firmware update:
ftp://ftp.hp.com/pub/softlib/software3/COL4415/oj-14700-3/HpAiOFWUpdate2_2.exe
NOTE: Clicking the link may give an error indicating it is
invalid. If this occurs, copy the portion of the address
on the remaining line(s) and paste it at the end of the
address showing in your browser until the complete address
is displayed in the Address box.
1. Download the file "HpAiOFWUpdate2_2.exe" to a local hard drive. Make
note where (in which folder) the file gets copied.
2. The hp all-in-one software for the OfficeJet 6100 series must be
installed on your PC before installing this firmware update. The
OfficeJet 6100 series must also be connected to your PC and turned on
before proceeding.
3. Locate the file "HpAiOFWUpdate2_2" on your hard drive and
double-click the file to install the firmware update.
This should resolve the issue. If you need further assistance, please
reply to this message and we will be happy to assist you further.
You may receive an e-mail survey regarding your e-mail support
experience. We would appreciate your feedback.
Please visit our Owner Services Web site for details on keeping your HP
and Compaq products up and running.
http://www.hp.com/home/ownerservices
I hope this helps
Mike
Jun 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Unable to create MSXML Instance
First we need to know the operating system installed in the computer.
If you are using XP. Then perform the steps given in the webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00516936&cc=us&lc=en&dlc=en
If the issue still persists then search for the file hpqscnvw.exe(scanning file) and then try to scan from there.
Jun 05, 2008 | HP Photosmart C6180 All-In-One InkJet...
perhaps you can relate to me how this is connected with a printer issue?
May 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hp Deskjet F340 All in one
that's Microsoft XML instance...seems that perhaps your printer is having an interpretation issue? Does this happen all the time, or perhaps on only certain document print jobs?
Apr 06, 2008 | HP PSC 2210 All-In-One InkJet Printer
Photo and Imaging Director
ok...try a test page first, with printer off the computer completely
and..check for newest printer drivers here
Feb 19, 2008 | HP PSC 2210 All-In-One InkJet Printer
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Scan error
Could you please provide me the exact error message you find on the screen.
Oct 09, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
105 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
