Question about Olevia LT37HVS 37 in. LCD HDTV
Hdmi cord
What does a hdmi cord do and where does it go if I have a 26in olevia hd tv and it is hooked up to cable without the hd box can I use an hdmi to bring it in and how?
    President:
  • 2,961 Answers
The HDMI cable sends all the audio and video down one line, and unscrambles scrambled high def content when required, and fits in the rear of the tv, the slot looks very similair to a usb slot.
If you cable box has an HDMI slot you can use that instead of a scart lead and choose HDMI on your tv output
Posted on Aug 18, 2008
Trying to hook up my panasonic tc-p50c2 to comcast hd digital cable box and cant get it to work with hdmi cord..nothing is showing
Use only the hdmi cord to hook it up and go to menu on the tv and select hdmi for hook up and you should get a picture. Make sure your cable cord is the only cord running to the cable box , you don't need any other cord.
Feb 09, 2011 | Panasonic TCP50C2 50 in. TV
How to hook updvd player to tv set
if the dvd player has hdmi connection use that.
if the TV has hdmi input use that.
if you can do both of these then use the TV remote to switch input to hdmi when the dvd player is on.
as an extra you can use toslink optical or coaxial digital cable from TV to home theater receiver for surround sound.
Jan 02, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
I have an olevia hdmi capable tv and a non hd verizon box what do i need to hook it up cable wise
The best picture would be HDMI, but as you stated the cable box is not HDMI. The next best connection is component cables (red,green,blue) from video output of cable box to video input of TV. You will also need RCA audio cables (red and white) from audio output of cable box to audio input of TV. I hope this helps.
Oct 27, 2009 | Olevia LT37HVS 37 in. LCD HDTV
I have an Olevia 23t lct hd tv. I am plugged in
you said you are using composite cables..? that means you have some kind of cable box ? if you want to get HD channels you have to use a HD box that is supplied by the cable company.. the HD cable box then has to connect to the tv with component cables (green,blue, red cables) or HDMI cable.. to send the HD signal to the television.
May 13, 2009 | Olevia 237T 37 in. LCD TV
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Aug 20, 2008 | Olevia LT27HVX 27 in. LCD Television
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
May 13, 2008 | Yamaha RX-V661 Receiver
My best guess would be that the resolution settings on your reciever are set too high(It's putting out an HD signal the TV can't display) Plug in through Composite or component the the box and resolve this through you Cable box's menu, then reconnect the HDMI cable.
Dec 23, 2006 | Olevia LT27HVX 27 in. LCD Television
Olevia LT37HVS 37 in. LCD HDTV Logo
256 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
