THOMSON SCENIUM 44" TV has a possible faulty power supply or loose connection in the unit as it will not turn on (standby light flicks on and off). My 1year old would constantly turn the TV on and off and this has most likely caused this problem! how much would it cost to fix it , New power supply?
    Scholar:
  • 167 Answers
HELLO. yes that would hurt the set , turning it off & on. !!! sound's like it might have blowen a horzanl out put.!!! or it could be a bad contack.!!! a cold solder joint.!! or dry scoket.!!! the need's to be resolder.!!! the price for a new power supply could be around $85.00 to $200.00 at a shop.!! and then there is labor to install it.!! At $65.00 to $125.00 hr. so your looking at around $225.00 to $ 450.00. its depend's where you take it .!!! call around first and ask who much they would charge you first.!!! hope this help's you "GOOD LUCK"
Posted on Aug 18, 2008
What does 3 flashes on the standby light on a Thomson scenium 44jw 611s mean
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Feb 25, 2015 | Thomson Televison & Video
9 year old Sony Trinitron TV 27 inch; a red light is flashing "standby, timer"; have tried to cancel this but the TV won't turn on, just hear a clicking sound when pushing the power button
The key here is the number of blinks. The standby light should blink a count followed by a few second pause with the count repeating. That count coupled with the model number will giveme enough information to provide you with a solution. Can you uipdate this with that info please?
Thanks,
Dan
Sep 16, 2008 | Televison & Video
I don't have s stanadard TV set (CRT) with pre-digital tuner. I have a Sony PVM-2950 (2950Q) CRT monitor (no TV signal tuner, dumb tube). It accepts external signal feed. Today, the red...
Hello. You might try to re solder the power supply and deflection area, Also the common problems of this TV are the capacitors that lose value. But I think you have loose connections on the card. Good luck, if you have any questions, I'm here to help you with more details. thanks
Aug 14, 2011 | Televison & Video
We went to bed and switched the tv from standby to on and after 1 min the tv turned its self off back into stanby, now if you turn it on it flicks onto a black screen with dtv in the corner and switches...
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
This will help you in solving the problem....
Jun 18, 2011 | Televison & Video
Tv not coming on just red light flashing on and
thomson scenium jw 611s not coming on just red light flashing on and off at front of tv
Jul 13, 2010 | RCA Scenium HD65W20 65" Rear Projection...
Sony FD Trinitron WEGA KV-34HS510 34" TV won't turn on. Standby light blinks 7 times
  • Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board). This may help !!
Feb 20, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Problem with tv
Hello,my problem is my t.v is power supply is damaged.i have found part # T 04 faulty.
Jan 21, 2009 | Thomson LCDB 03B 27 in. Television
TV wont turn on
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board)Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Apr 06, 2017 | RCA Scenium HD65W20 65" Rear Projection...
Thomson scenium 44
i have had the same problem.....
my problem was gone after that i cleaned the tv and removed all the dust and **** behind the tv.....
Nov 04, 2007 | Televison & Video
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
Electro Med Services...
