Reg. printing of memory received messages
Hello, i am a user of workcentre pe220 all in one xerox/fax/printer/scanner.
Can you assist me by advising how to get the print out of fax messages received in the memory. i mean memory received messages. Mine is telephone *** fax so nowadays the fax messages automatically stored in the momory and i am not able to understand how to get the same printed
and also can i get the memory received messages in my laptop followed by printing.
Kindly advise
Presannakumar. R
  • Anonymous Sep 04, 2008
    You should change your toner.
    Thanks,
  • Anonymous Feb 17, 2009
    I have the same problem.. please advise what to do..
    ruchir
Yes, after refilling the cartridge, fax in memory automatically print out with charms. :) thanks for your help.
Posted on May 20, 2010
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Dec 15, 2010 | Xerox WorkCentre PE220 Series
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Memory full
This message usually shows up when you've received many faxes and haven't printed them, or when you have attempted to send faxes but they never made it and were kept in memory for a later date.
I would search in your user's manual how to clear the memory, since each manufacturer has a different way to do this, and the machine's menuing systems also differ from one manufacturer to another.
Aug 25, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Xerox workcentre PE220 paperport install only
Dear user,
pl find paperport software from this url.
www.support.xerox.com
Regards,
Ravindra Shah
Jun 29, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox pe220 cannot copy
i have the same problem too with my pe220. fortunately, i just purchased a new one which i planned to give to it to a relative, and I was able to figure out that the cause of the "function impossible" displayed.
the problem just occured this morning and I have tried downloading and updating the firmware too, clearing the memories, etc but cannot get the copier to work (can't print thru the pc also).
i then borrowed the new toner cartridge of the new pe220 and installed on my old one and i was able to print and copy again. the problem then is due to the chip memory.
the problem now is how to reset the serial eeprom chip in order to reuse the toner cartridge again.
hope this helps.
Feb 24, 2009 | Xerox WorkCentre 220 All-In-One Laser...
Xerox PE220 scan
you do it by install the driver and then the scanner cd and you have the possibilte to scan via pc
Feb 21, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Promblem with xerox printer
This is solved with if you do a clear all Memory procedure under the Maintenaince settings
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Error message; no printing of text
What application were you trying to print from at the time. Does the printer give this error message all the time or only from this program? I need this info to assist you bzoe...lilacgerry
Aug 30, 2007 | Xerox WorkCentre M940 InkJet Printer
783 people viewed this question
jasbo
jasbo
