Question about Canon LASER SHOT LBP-2900 Printer
Cannot recognize usb port
When i run set up from installation cd set up does complete and warnings display usb does not recognized
  • pindordan Aug 21, 2008
    Same problem , I try all advices but no result . I buyed since a week but i could not conect it yet: "cannot detect USB connection" :( . Finaly I put yhis brand new catastrophe called LBP 2900 to rest untill those from canon will think about fixing the driver.
  • David Delaroche
    David Delaroche May 11, 2010
    OS and service pack level please?
    Problem Solver:
  • 8 Answers
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying cannot recognize usb port - icon_smile.png.
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Remenber to Rate me on FixYa!!
Thanks
Posted on Aug 18, 2008
Smoking??
Posted on Sep 14, 2008
Strangely, but my problem was solved by using a diferent (old) usb cable . I tried 3 different usb cables all new but it did'nt recognise conection. Than i tried an old usb cable wich was shorter than the other ones. Strangely but this way it work't for me .. longer usb printer cable don't work , shorter yes ...
Posted on Aug 25, 2008
Color printed pages are too light.
  • Troubleshooting Setup and Install If your device is not recognized:
    • Verify that your cable is USB 2.0 high-speed compliant.
    • Ensure that your cable is connected correctly. Remove the USB cable, look at the end of the cable, and then match it to the pattern on the USB port. Make sure that it is not upside down. Insert one end of the USB cable completely into the USB port on the HP device and the other end into the back of the computer.
    • Check that the peripheral is turned on. Peripherals will not be recognized if the power is off.
    • Ensure that your USB cable is no more than 15 feet or 5 meters in length.
    • Check that the USB port is enabled. Some computers ship with disabled USB ports.
III. INSTALLATION INSTRUCTIONS When operating in a Windows environment, the CD-ROM setup or installation software detects the version of the operating system that you are running. The software is installed in the language that you have selected. For example, if you are running an English version of Windows and have the language preference set to Spanish, the installation utility will install the Spanish version of the printing software for the appropriate Windows version. INSTALLATION OPTIONS Two methods are available for installing printer drivers and software components for the printer.
  • Full (Recommended) . Installs everything that your device needs to work plus HP Solution Center:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL6 driver
    • HP Toolbox FX . Allows you to change some printer settings and contains documentation and self-help tools.
    • Screen Fonts . Printer-matching TrueType fonts help ensure WYSIWYG printing.
    • HP Color LaserJet 2605 series printer documentation. A list of documentation, which includes information about product operation, troubleshooting, warranty and specifications, supplies, and support.
    • HP Solution Center . Use HP Solution Center to gain access to product-specific software and on-screen help. By using HP Solution Center, you can access the HP Shopping Web site and update your HP software. If you have the HP Color LaserJet 2605dtn, you can also transfer images from a photo memory card. To start HP Solution Center, click Start, Programs, choose the HP program group, and then click HP Solution Center.
    • HP Photosmart Transfer . Software for transferring images from photo memory cards to your computer (HP Color LaserJet 2605dtn only).
    • HP Product Assistant . This software detects problems that occur with your HP products and can offer solutions to help you resolve those problems.
    • HP Software Tour . Use this for an overview of the software features.
    • HP Software Update . Use this software to check for software updates for your HP products.
  • Minimum . Installs everything that your device needs to work. The following is a list of available components:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL 6 driver.
INSTALLING SOFTWARE ON WINDOWS 2000 and XP Printing system installation from CD-ROM, Internet download
  1. Close all programs.
  2. Insert the CD-ROM.
  3. If the HP printing system installer program has not started after 30 seconds, complete steps 4 through 7.
  4. From the Start menu on the taskbar, select Run.
  5. Browse to the root directory for the CD-ROM drive.
  6. Select the SETUP.EXE file, click Open, and then click OK.
  7. Click Install.
  8. Follow the onscreen instructions.
USB Installation for Windows 98 Second Edition, Windows Me and Windows Server 2003 (Plug and Play Install)
  1. Turn on the printer and computer.
  2. Verify that the printer displays “Ready.�?
  3. Attach the USB cable to the printer and computer.
  4. When the Add New Hardware Wizard appears, click Next to install the USB Printing Support.
  5. In the following dialog, select option Search for the best driver for your device, and click Next.
  6. Make sure the HP Color LaserJet 2605 series CD-ROM is in the CD_ROM drive, select Specify a location, browse to your CD_ROM drive, and select the Drivers folder, then either Win98_Me( for Windows 98 and Windows Me) or Win2000_XP (for Windows Server 2003). For example, CD ROM drive:\Drivers\Operating System\Language. Choose OK, and then click Next.
  7. For Windows 98 SE, in the USB Printing Support dialog, you should see the path and file name. Click Next. For Windows Me and 2003 Server, this step may not apply.
  8. Once the files are copied, click Finish.
  9. Steps 4-9 will repeat to install the printer driver. File names will change. At step 9, you have the option to rename the printer. Click Finish. After files have installed, click Finish to close the dialog.
Network Installation for Windows 98 Second Edition, Windows Me, and Windows Server 2003
  1. Download HP's Install Network Printer Wizard.
  2. Run Install Network Printer Wizard and follow the on-screen instructions.
INSTALLING SOFTWARE ON MACINTOSH OS 10.2.X, 10.3X, and 10.4.X USB installation instructions
  1. Insert the CD-ROM.
  2. Run the installation utility.
  3. After the software installation is complete, attach the USB cable to the printer and the computer and then restart the computer.
  4. After the computer has restarted, open the Print Center or Printer Setup Utility to see if the printer name appears in the Printer List.
  5. If the printer name displays in the Printer List, the setup is complete. If the printer name does not display in the Printer List, go to the next step.
  6. Click the Add button, and then select USB from the drop-down list. 7. Select HP Color LaserJet 2605 and then click Add. The printer name displays in the Printer List. Setup is complete.
Jan 27, 2010 | HP LaserJet 2605DTN Color Printer
Pny 4gb pen drive is not working
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 02, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Pixia MP600 had been working fine but now computer with Vista fails to recognize it and says something on connected to USB has malfunctioned. Also where can I get a installation cd that is in English. The...
while you install the software cd . you can see the language settings for display there you can change your own language. dont connect the devices before you install the software cd while you install the cd it will ask you the default settings from there you can change the setings.
Jun 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
2wire wireless usb adapter installation for desktop
elomarcillo1,
You are attempting to install a (brand name) 2wire wireless usb adapter, normally the SBC DSL CD is ONLY what you would use to set up your SBC DSL modem. You should have a specific 2wire CD that you put in your CD Drive when you want to install the 2wire wireless usb adapter. Can you locate this CD?
-ms
Nov 09, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Belking wireless adapter install
when you are advised to connect the usb adapter, it will recognise it, then the usb host controller is installed to recognise the adapter,but it should continue to instal the driver and then recognise it as Belkin 54g, if not, then you need to keep the cd rom in and then force it to install the driver from your cd drive, but it may not be compatable with ME unles you have a windows 2000 driver.
When the installation is complete you should in any case have the belkin software icon on your desktop to set up the adapter, if not then the software has not installed fully.
It will also be listed in add/remove programmes if it's fully installed.
Sep 22, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Help
I can scan but I cant save it to my computer.. What will I do?
Aug 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Driver ViMicro USB PC Camera 305
Hello all ز
You can download from here Aldiriver .
Jun 10, 2008 | Computers & Internet
No Display
i can help with the computer registering it...
insert zen v plus install cd
exit out of autorun for cd
go to control panel
click on system
click on the hardware tab
click on device manager
click on portable devices
right click on your USB device with the yellow warning sign
go to properties
when it tells you that the drivers arent installed... go to the browse button and select your zen v plus install disk
hit ok and it will find the drivers that way...
as for thedisplay... once you get the computer to recognize its there troubleshoot it.
Mar 26, 2008 | Creative Labs ZEN V Plus MP3 Player
I have bought Memory 2 Go's USB 2.0 drive. My computer which has window 98 system is unable recognize.
Run the cd that came with it.
Your computer only has a 1.1 usb port setup it may give you a warning..
Jan 13, 2008 | Computers & Internet
Problems installing JVC USB drivers
The JVC USB driver was written before introduction of the Windows XP system. This warning is displayed with other manufacturer’s digital cameras, also, and is not strictly a JVC phenomenon. In order to use the USB interface between the camera and your computer, select the “CONTINUE anyway” option provided in this warning display. To JVC’s knowledge, there are no negative effects to using JVC driver with Windows XP.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Canon LASER SHOT LBP-2900 Printer Logo
1,432 people viewed this question
old marine
old marine
