Question about Lexmark Office Equipment & Supplies
3400 series power button will not turn off and window message says cover open
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
What's the model number?
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
SOURCE:
HP Photosmart C4180 message "Scanner
Try resetting the printer:
Reset the printer
-Disconnect the Universal Serial Bus (USB) cable from the back of the printer, but leave the printer turned on.
-Open the cover of the printer and remove the print cartridges.
-Close the cover and wait for the Insert Ink Cartridges message.
-Disconnect the power cord from the back of the printer and wait for one minute.
-Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
-Open the cover and reinsert the print cartridges.
-Close the cover. If prompted, print a calibration page.
-Reconnect the USB cable, and try to print a print job from the computer.
Hope that helps!
Feb 07, 2011 | HP Photosmart C4180 All-In-One InkJet...
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Check ink u163 error message
Firstly I suspect you are not using genuine cartridge or you have refilled the cartridge.
To fix this you need to disable the ink checking procedure.
Do you know that low ink or ink has run out message appears once cartridge empty. If you want to use refill ink in that cartridge then you need to deactivate ink level to get your printer run as usual. Check the following tips to fix low ink error message in case of refill ink usage. Below some methods to deactivate ink level detection function for some models due to its similarity.
METHOD I:
Press RESUME/CANCEL button once
Related models:
BJC series: bjc3000,8200,etcS series: s400,600,800,6300,9000etc
i Series: i255,320,350,355,450,470d,550,560,850,950,6100,6500,9100,etc
Pixma series: ip1000,1200,1300,1500,1600,1700,2000,2200,3000,4000,etc
METHOD II:
Hold down RESUME/CANCEL button for 5 seconds or more
Related models:
Latest models of Pixma series: ip1880,1980,3300,3500,4200,4500,5200,6700d,pro9000,9500,ix4000,5000,etc
METHOD III:
Press START button once, select COLOR button for colour cartridge; BLACK button for black cartridge
Applicable models:
Pixma MP150,160,170,180,450,460,475,etc
METHOD IV:
Hold down STOP/RESET button for 5 seconds or more
Applicable models:
Latest models of Pixma MP/MX series: MP145,228,245,520,800,850,970,MX308,318,7600,et
Jun 21, 2009 | Canon MX300 Office All-In-One Printer
Series 3400 printer
If your printer still in warranty please replace the printer or This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located..
Good luck....
Oct 30, 2008 | Lexmark X3470 All-In-One InkJet Printer
My Fax on my lexmark 3400 series does not work.. How do i reserve message throw my fax.. And how should it be hooked up..
need to "hook up" acer 8spire T180, desktop with Windows Vista to a Lexmark 2500 series combo unit fax and printer. Do I need a Modem, for this???
Oct 13, 2008 | Acer Aspire™ T180 PC Desktop
HP Scanjet 3400 C
Unfortunately, The 3400 series cannot be cleaned on the underside of the glass. Scanners with the capability of having the under side of the glass cleaned are listed below.
Aug 03, 2008 | HP Scanjet 3400c Flatbed Scanner
Lexmark 3400
im looking for the software to run 3400 can you help me get it
Jul 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark 3400 printer display says cover is open. Cover is not open. apparently it is mis reading status. will not print or turn off. Its stuck. What do I do? D.S.T
do a hard shut down..unplug power cord...that would make it go off. them leave it off for 2-3 minutes..then turn it back on and let me know the status
Jun 05, 2008 | Office Equipment & Supplies
Lexmark 3400
printer screen shows cover open but it is,none buttons will work
Jan 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 3400
Looking around with Google it could be how your ports are set.i.e USB or Lpt
Dec 09, 2007 | Lexmark X3470 All-In-One InkJet Printer
Open Questions:
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
