Question about Dell Latitude CpX Laptop PIII 500 Mhz 13.3" TFT 10 GB HD 128 MB RAM CD Floppy 56K Modem Internet and... (DCPX500CD) PC Notebook
[Repost] Can't start windows
When I start my computer, it says
"Primary hard disk drive 0 not found"
"No bootable device selected"
"strike F1 to retry boot, F2 for setup utility"
It actually booted to windows before but suddenly now it doens't work
Comment by fmfranchise, posted on Aug 18, 2008 It stopped working yersterday. In the bios it says none for primary hard drive. Can this mean my hard drive crashed? What do I have to change in bios?
  • 44 Answers
Don't quot me on this without having more detail but in terms of the age of the laptop, it could be dead, meaning either the disk spins up but can't read or it just doesn't get power.
In Bios, are you able to make an auto selection for the primary boot device? If so try to set it to IDE 0, if that doesn't work and wasn't set to auto before try that.
In laptops they get moved and shaken during operation which is bad for hard drives considering there are things aligned just right internally. You could probably get a 20gb laptop drive for around $30.00? I would check around online for the best prices and availability and make sure it matches the specs of the laptop . If you have important info on your hard drive you will need to back it up before this happens and is recommended to do it regularly. If you didn't back it up then a professional may have the capabilities to do so and might have a 10Gb HD available if you can't find one and can install windows on it for you.
Posted on Aug 18, 2008
    Novelist:
  • 125 Answers
Ok i had the same problem today:
firstly check to see if the HDD is on its own IDE channel (ie. not sharing with another IDE device such as a CD-Rom or DVD drive)
if yes disconnect the Optical drive or other device on the IDE channel and boot and if it still isn't working change the IDE interface used if this still doesnt fix the problem.
Boot with the Windows Install CD and see if you can do a system repair / chkdsk , if the HDD is still not detected you possibly have a problem with your motherboard / HDD
to determine if its the hard drive if you have another HDD spare which you can try boot off give that ago and if it succeeds your other hard drive is failing time to get a new hard disk.
If you still have no success time to look for a new computer or get it changed under warranty if you still have it ?
No bootable device detected
If you strike F1, the system retries as said in the comment. That does'nt solve anything. Rather strike F2 which allows to enter the setup menus of your computer.
In this area you should understand what you are doing. Any update of setupdata may prevent further restart. At least take note of values and changes. You exit setup via a question "update Y/N". Then the computer restarts.
Anyway, in the setup menu you may inspect the devices and see if you the system identifies the disk. If not it may come from a bad connection of hard disk (sata pins, ...) or from low level disk information (format information).
With setup menu you may get in the boot order menu, that allows for the selection of an alternate boot media. You may boot on an installation media, ( install DVD generally, like originall windows install DVD) in order to understand and repair the situation, or from a rescue system like UBCD. You may also try Ubuntu from the CD without installing, just to verify if you may see the disk in the configuration.
Regards
Jul 09, 2014 | HP Computers & Internet
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Oct 27, 2009 | Dell Inspiron 1521 Laptop
No bootable devices-strike F1 to retry boot,F2 for setup utillity
Is there a hard disk installed inside the computer? try reconnecting it.
The motherboard, the hard drive, or the connector could be faulty in this case.
Remember to unplug and remove battery if you open the laptop, the hard drive is in most cases in the bottom under a cover with few screws or in some dells its on the side with few screws and comes out from the side instead from the bottom.
May 22, 2009 | Dell Latitude C600 Notebook
No boot device available
Make sure all the connections to the Hard Drive are tight and secure. Then see if it will boot. If not then try loading a windows cd and see if it detects the Hard drive. If it does not the hard drive is no good if it does try running the automated system recovery you may have a corrupt MBR file.
Dec 22, 2008 | Dell Dimension 4400 PC Desktop
Can't start windows
The issue you are having is that your computer is not seeing the harddrive or the boot drive. This could be a simple fix from the bios by telling the computer what device it needs to boot from which in this case is your hard drive.
You say that it did work and it was working how long ago was that? It also could be more serious in which you hard drive has crashed or exceeded its MTBF (which means "mean time before failure").
Aug 17, 2008 | Dell Latitude CpX Laptop PIII 500 Mhz...
Dell latitude c640. comes up with error immediately after ram check displays... "primary hard disk drive 0 not found no boot device available - no bootable devices--strike F1 to retry boot, F2...
Seems to be a problem while detecting the hard disk. Please contact customer service if the laptop is in warranty.
Let me know what happens.
Apr 30, 2008 | Computers & Internet
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Dell Latitude CpX Laptop PIII 500 Mhz 13.3" TFT 10 GB HD 128 MB RAM CD Floppy 56K Modem Internet and... (DCPX500CD) PC Notebook Logo
118 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
